My Panasonic TH42PZ80 makes a slight buzzing noise when switched on - is this usual or is there a problem?
  • jamest2500 Dec 15, 2008
    I have also spoken with Panasonic and they advised me that the set has 4 fans within it and this is what can be heard.
  • 4,234 Answers
If the buzzing is coming from the set itself rather than the speakers, then this is normal. The bussing should only be loud enough to hear when you are close to the set. If it is loud enough to hear from across the room, it is not normal and could be a sign that the power supply is starting to fail. Which case best describes your situation?
Dan
Posted on Dec 15, 2008
Model SA-AKX50. Why is it making a continual buzzing noise?
A low frequency buzzing sound is usually the result of a bad component in the power supply.
Dec 05, 2015 | Panasonic Audio Players & Recorders
Microwave makes buzzing noise when using
If buzzing but not heating it could be $10capacitor or diode.
Oct 13, 2014 | Panasonic Microwave Ovens
Emerson 1081 pool pump makes buzzing noise when i turn it on wont start
Either something blocking the impeller / shaft, from turning or the motor failed.
You can try to manually assist the motor, by removing the small cap at the back of the motor, getting a flat blade screwdriver, and right when you flip the switch (get a helper) turn the shaft clockwise while it buzzes. If it takes off - possible Bad Capacitor? Try a couple times if it doesn't take.
if bad capacitor, make sure you get the exact replacement, or 'Slightly Greater' will work - and I refer to the MFD number. Don't go smaller!
May 29, 2014 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Buzzing noise-Model #KX-TGA931T
There should be a "CH" or 'CHAN" button. Press it till it stops.( It is the channel button). or turn down the volum on the hand set.
Dec 26, 2013 | Panasonic Lands Phones
Buzzing noise on xbox when switched on
Seems like the fan should be cleaned. If it is making a loud buzzing noise it usually means the fan is working extra hard. Hope I helped.
Jun 20, 2010 | Microsoft Xbox 360 Console
MP 3 player and noise
try different headphones and/or new battery. buzzing is usually a short/bad/dirty connection somewhere.
Jan 20, 2008 | Panasonic SV-MP020 MP3 Player
Panasonic microwave buzzing noise
Yes, this is usually a shorted high voltage rectifier diode.
It is usually located behind the high voltage transformer and it attaches to the magnetron and to the chassis.
For ciritical safety links how to test the diode, see: http://www.gallawa.com/microtech/diode.html
Panasonic replacement parts can be found here: http://www.pasc.panasonic.com/epartr
Dec 06, 2007 | Microwave Ovens
Buzzing
The noise is caused by dust on one of the toroidal transformers(usually a round looking thing with wire wound around it). Go to the back of your television and try and pinpoint were the sound is coming from. Turn your television off and blow it out with compressed air if it is close to air vents in the television. If you cant see it you might have to open your television back panel.
Nov 23, 2006 | Panasonic TH-37PE30 37 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
