Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
ET1CHMXKQ02 TOP FREEZER REF.
LEEKING WATER INSIDE. THE BACK IS SEALED BY BRADS. NOT ASSEDABLE
  • 1 more comment
  • james vastine Mar 17, 2007
    CONTACT ME AT jcvast@yahoo.com
  • james vastine Mar 31, 2007
    we are going to defrost this weekend.we will you know if this fixes the problem.
  • Anonymous Feb 13, 2008
    somehow water is leaking on the inside and i have no idea where it is coming from?
  • 63 Answers
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Posted on Aug 30, 2007
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Ice on top of inside refrigerator and items in back top shelf are frozen turned down temp to 3 and it melted , put back up to 5 and new ice formed on top of refrrigerator
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
Have a Whirlpool refrigerator/top freezer model ET1CHMXKT06. Water from freezer drips into refrigerator. How do I stop this?
Check drain in the freezer which probably runs through the Ref. Pour water in Drain in back of
freezer and see if it drains. some may be getting inside ref.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 10, 2011 | Whirlpool Refrigerators
I have a Kenmore Coldspot ref, model # 78862898. The freezer literally has icicles hanging from the roof of the freezer, frost on food items. The ref isn't as cold as it should be with water...
Sound allot like there is a serious air leak....Is the door sealed good? You also have a defrost drain line plugged up behind the freezer panel you will need to clear that out with hot water after removing all the ice. watch this video to see how to replace the defrost thermosthttp://www.youtube.com/watch?v=z-h541_14ZE
May 26, 2011 | Kenmore Top Freezer Refrigerator
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
Water is leeking below the refrigerator. I cannot see where the leeking is coming from. Any ideas where to look?
There could several reasons for the water under refrigerator. Leaking water connection to water control valves. leaking defrost condensate pan or blocked condensate drain beginning inside freezer rear wall cause by ice or other gunk caught in the defrost drain line. Because leaks always happen differently on every model I will give you a page to look over and watch a small clip about fixing a refrigerator leak. One moment as I retrieve the information and links. Sea Breeze
Dec 22, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Refridge leaking water inside it...
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
May 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leeking on floor
most fridges and freezers have a small outlet hole at the very back of the inside make sure this is clear should have a small tub at the back of your appliance on the outside try this
Aug 15, 2007 | Kenmore 62232 / 62234 / 62239 Bottom...
Whirlpool modle ET1CHMXKQO2
if you cant get to the back the only thing left to do is unplug fridge until drain line defrosts
Mar 21, 2007 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
327 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
