Question about Ovens
The hot plate is heating up when the selector is in off position
One hot plate regularly heats up as if it is on a low setting. The selector may be out of alignment ?
  • 4 Answers
Hotplate heating up when regulator/selector switched off. Hi ,this is gil1714 in Scotland. Two possibilities on this one, 1) the regulator is faulty:- replace
2) if the control circuit (regulator) is wired on the neutral side the hotplate may be leaking current to
earth, thereby completing the circuit. This would only occur on a supply that was not protected by
an RCD. If so replace hotplate. Hope this is useful,
Posted on Dec 16, 2008
Why won't my GE P7 self cleaning oven get hot??.. When switching the oven on.. The indicator light does not come on.. but if I position it half way between off and bake ,the light comes on but no heat...
Could have a bad element in oven.or the selector switch could have a short electrically. I would shut the circuit breaker off and call an electrician to check it out.could cause electrical shock or even a fire.
May 17, 2014 | Ovens
Heat shield fixing
you could also find a bigger self tapping screw, but if you have corrosive metal I would replace the piece, as it can spread over time.
Dec 03, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
When using grill knobs get to hot to turn stoves 600 sidl
you are missing the heate plate that stops the knobs from getting hot go to ebay and put your model in and look for heate plate or some thing like that
Oct 12, 2012 | Ovens
I have a Zanussi ZHQ575 X Double oven, the main oven will not work when I select the Fan Oven setting. I have tried a new selector switch but it still will not work on this setting. The fan comes on but...
I have the same problem.... It's not the element gents, please read the question again... the oven heats up on the other settings it's just when you select fan oven (the most popular) I too have tried replacing the selector switch with no luck. Really need a wiring diagram.
Apr 14, 2012 | Zanussi ZHQ575 Electric Double Oven
Oven will not heat up but stove top works
Hello there
Please read the entire solution to see which best decribes your problem ok
first.
If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note… If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these,
Jun 27, 2010 | Kenmore Ovens
My electric hot point oven doesn't heat properly. The top part of the heating element does not come on.
It is either a faulty element, or a faulty regulator/selector switch tha t is causing the problem.
Hope this helps.
Dec 18, 2009 | Hotpoint Ovens
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Oven not heating properly
you sure you have 240volts at the unit??? chk for 120+120 volts to get 240volts,one leg out and you'll have little to no heat condition
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Gaggenau oven won't heat on convection setting
    this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
    May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
    Ovens Logo
    138 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
