Question about NEC Versa FX Notebook
Nec laptop water fell on me and wet the laptop.instead of me dryin it b4 pluggin i plug it and now the screen is not displaying.what do i do?
Cricket phone screen goes white
You could try and have it repaired but most likely the damage has already been done to the phone so no guarantee it's even fixable. I'd get a new phone maybe one of the water proof one's :)
Sep 10, 2013 | Cricket Wireless Cell Phones
My camera samsung es65 fell in water...what should i do now....when i kept battery and turned on welcome screen came and again it vanished..when we press buttons green light was blinking but screen is not...
It may be possible to dry the camera out by leaving it in a warm dry place for a long time (like weeks). However, you may have damaged it by turning it on while it was wet.
Oct 27, 2010 | Samsung Cameras
Hi sorry i hve a laptop nec versa L2100 n hve vista home basic b4 n now i just change to windows 7 but i couldnt get the cam fix
mcdevito75 here, Why not just up-date your vista?? type in serch from any page Vista up-date. Hope this helps.
Jul 18, 2010 | NEC Computers & Internet
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
External Hard Drive not operating normally
sounds like you droped your drive or shook the poop out of it
eithor way it's time 4 surgery
first open the case and make sure the plugs are ann pushed in my ide cable fell out 1 time and it did the same thing
if a cable fell out then u might get her back
i asume you have checked your fuse and used a dfferent usb cable first right be cause somtimes as we all know usb cables break and die so we would have tried a different cable b4 you posted this question
Sep 16, 2009 | Western Digital Computers & Internet
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Phone fell into tub and now have no screen info
key to saving your phone is to not charge it after it got wet. to get it at least partially working take out the battery and take a blow dryer and carefully warm the phone. do not keep the heat near the screen for long periods of time. after drying for about 20mins leave the phone alone plugged into the charger without the battery inserted for about 45mins. after that you can check the results. put the battery in and test to see whats working and what isn't.
hope this helps
Apr 21, 2009 | Motorola Mobility ic502 Cellular Phone
Any idea if I can hook my laptop up to my EDTV?
Yes, if your laptop has a VGA out port (that is the external display port - usually blue with 15 pins).
The NEC display has a VGA input on the right-hand side.
You just need a VGA cable that you plug in both connectors.
Then, read your laptop manual to determine how to activate the external display (usually the FN key with an other key that has a display icon on it).
On the NEC display, make sure it is using the RGB1 input (use the remote to activate this input).
That should do it.
NOTE: Make sure your laptop is using a reasonable screen resolution (that is 640x480 or 800x600).
Apr 17, 2009 | NEC Plasmasync PX-42VM5A 42 in. EDTV-Ready...
Blank screen
so there is a picture and the computer works fine other than that this is best taking to a computer shop because its likely to be a screen problem untill then you can plug your laptop into a normal computer by pluggin the computer screen into the vga port on the back of your laptop
Jan 28, 2008 | Compaq M2105USEC214UA Notebook
NEC Versa FX Notebook Logo
59 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
