Question about AOpen 19" LCD
Power Light Blinks with no display on screen
I have an AOpen Monitor Model 75Ps with speakers, which I purchased in 2003. When I power up my computer, the power light blinks for about 15 minutes with no display showing on the screen. Then the light becomes constant and the display on the screen becomes visible. Can this be repaired easily. If so how? If not, please advise where I can get it repaired. Also, any idea how much a repair of this type would cost?
Thanks for te assistance.
Lewis Newman
    Problem Solver:
  • 14 Answers
Hi
If you switch on your screen it just goes dead again. If this is the case then all you have to do is replace your backlights of your lcd. The backlight are florescent tubes Which are gas filled and they have a lifespan of plus/minus two to five years. Once the gas is depleted the backlights try to go on then switches off
This problem occurs alot on all different lcd screens eg. ibm, gigabye and alot of other name brands and even the cheapies. the backlights come in different lengths so you have to open your screen and remove them carefully so that you dont damage or crack the liquid crystal. i have been repairing lcd screens for a while and this is the problem most of the time.
You can order the backlights from RS components. They supply and sell backlights if you wish to do it yourself
Glad to be of any assistance
Posted on Jan 10, 2009
    Novelist:
  • 157 Answers
Does this happen when it has been off for an extended period of time?
What I am getting at is this...
I've had devices (monitors included) that when they were cold (just turned on) they didn't want to function right, but after a while of it being on, then they would function right.
As far as repair, I have found no schematics nor sites with replacement parts. My only suggestion is to call their customer service:
Phone: 800-444-8086 (ext. 203 or ext. 204)
E-mail: rma@aopencenter.com
Sorry I couldnt do more.
Have a Happy Holiday,
TJ
Posted on Dec 15, 2008
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
How to fix aopen F75PS Display Power Light Blinking, Display Won`t come on.
A blinking power light typically means there is no signal from the video card, so check the connections and try another monitor (or plug the monitor into another computer) first to see if the video card is perhaps the real culprit.
Mar 14, 2010 | Computers & Internet
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Hp 1730 monitor will not turn on. The power light on the front of the monitor blinks. Screen is black looks to be off. when i push the power button nothing happens.
There are multiple circuits for this model. I suspect your model is PE1237. If so this model frequently has bad solder connections at the AC socket. Also capacitor 2119 or capacitors 2041 & 2031 can cause no power up. They normally are bulging if bad.
If your model is PE1238 (BenQ), you may see bulging capacitors in the power supply.(1000uf/25v)
Monitor Mike
Dec 09, 2008 | HP Serial adapter (17302A)
AOPEN LCD monitor
hi
This problem occurs alot on all different lcd screens eg. ibm, gigabye and alot of other name brands and even the cheapies. the backlights come in different lengths so you have to open your screen and remove them carefully so that you dont damage or crack the liquid crystal. i have been repairing lcd screens for a while and this is the problem most of the time.This also affects your power supply as the backlights sometimes arc inside and causes the power supply to act funny the reason for power light flashing
Jul 08, 2008 | AOpen 19" LCD
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
AOpen 19" LCD Logo
282 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
