Question about Vizio L32 32 in. LCD HDTV
Why wont my vizio tv turn on, its plugged in and all but not even the light will go on what can i do
  • 3 more comments
  • Anonymous Dec 19, 2008
    Same thing and the same week?! It has the gold indicator light but it won't turn on manually or with remote.
  • jorgepartida Dec 27, 2008
    television just went out and will not turn back on
  • ugsteve Dec 31, 2008
    I have the same problem, light on, but tv doesn't turn on or off. What is a psa board?
  • Anonymous Jan 09, 2009
    I bought mine on the 31st of December and it worked great FOR 8 DAYS. Now it won't turn on at all.
  • Anonymous Jan 16, 2009
    my vizio p50 of two and a half years, has just done this exact thing. has power but just a orange standby light lit on the front. Will not turn on at all. I've been dealing with vizio for weeks now. As it turns out vizio are honoring the warranty even though mines out of warranty. I believe this is as a courtesy to Costco and AMEX. They have extended the warranty by 12 months. But mine is an older model. I have waited to be contacted by the vizio repair agent in Chicago for 2 weeks now, still nothing! So after yet another call to vizio they tell me they will do a swap out for a new 50 inch tv as the parts needed to fix mine are on back order for several months. try calling vizio and ask,(Nicely is key here). and they might just swap it out for you for a new one. hope this helps. As I'm sick of seeing my $1900 paperweight on my wall...
Its a power supply issue, you need a new psu board.
Posted on Dec 16, 2008
Psu board
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Posted on Jan 25, 2010
  • 148 Answers
SOURCE: I have a brand new vizio 32L 40a flat screen I
Assuming the Vizio name is the powerlight, then this is your problem and solution........................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped you (or not), please rate, thank you
Posted on Feb 03, 2010
SOURCE: vizio vw42lhdtv10a 42
check out the power supply board! Look for popped capacitors. They either leak or swell up. They are the can shaped things on the board with the plastic coverings on them...you can usually see a swollen cap sticking up over its covering as a telltale sign.
Good luck and be careful
Posted on Mar 16, 2010
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
joeguest2
  • 2080 Answers
SOURCE: i have a vizio lcd
Here is a link to the Online User's Manual for your TV in case you don't have one already:
http://docs.google.com/viewer?a=v&q=cache:z4kjPAcpGywJ:www.vizio.com/documents/downloads/hdtv/VU42LF/Manual.pdf+vizio+VU42L+fuse&hl=en&gl=ca&pid=bl&srcid=ADGEESj4QgBLP8c9lcHQnjaCEE8jv7u6hr8LJ2nQPfaXPZSQ__EcWuaUV87DM4fstqd5caBPBDLL4oCW8_njGo1_NFx2nVCcrrleQrayRdd4-uK_UH0ss-9t9InUG6dUDYHDxroxPc29&sig=AHIEtbSDMOtw3BgFtzO6CkcU-FUNHlIYbw
Some LCD TVs have a fuse fitted right where the power cord enters the case and is accessible through a small removable panel. However, I didn't see any mention of one for this model in the manual or on related forums.
It certainly seems like you are not alone in your troubles with VIZIO products though. See the disparaging comments regarding your model tv at the following link:
http://hdguru.com/disposable-hdtvs-vizio-responds/108/comment-page-4/
Unfortunately none of them seem to have any solutions either.
Good luck.
Sorry I couldn't help more.
Posted on Feb 16, 2011
Vizio m420nv tv wont turn on but logo lights up
Test the PWR-ON terminal on the power supply and see if you have about 3.5 volts there
May 03, 2018 | Vizio Televison & Video
My vizio tv just has the vizio light on when i plug it in it wont turn on
Sounds like a problem in the power supply. Possible bad capacitors if you can have it checked out.
Apr 22, 2013 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
Vizio E320VL has yellow light but wont turn on even with a new Power Supply
The power supply get's it "turn on" signal from the main board. It is very likely you have a faulty main board. Do you have electronics experience??
May 15, 2012 | Vizio E320VL 32 in. HD Ready LCD TV
47 inch vizio blown fuse
i am having the same problem and my power light wont even turn on so i think it might be tht power fuse. Is tht what was wrong with urs?
Dec 18, 2011 | Vizio VO47LF 47" TV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
I plug the tv in and there is no power
Go to MENU at the Tv turn on the logo light option on.
May 08, 2010 | Vizio VP322 32 in. Plasma TV
My vizio wont turn on but the vizio organge light comes on please help
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you.
Mar 26, 2010 | Vizio L32 32 in. LCD HDTV
My vizio tv wont turn on. Any secret buttons that
Hi my name is Roety,
I can help you with your issue ,
 Check the AC plug, to reset the TV unplug and connect it. If the power light lights up check the input select button the TV needs to be own the correct input to view TV again.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jan 26, 2010 | Vizio VW32L 32 in. LCD HDTV
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
338 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
