Pictures not showing(VCR)
I have a Panasonic VCR.Recently a VHS cassete got stuck inside and i opened the cover and carefully removed it.I had to disconnect some of the ribbon cables as the tape had gone around many places.but i took extreme care not to affect the video head and other instruments.
after fixing everything back i turned it on and inserted a another VHS cassette. everything works fine except that now there is no picture showing. the menu screen works and sound also is there,but no picture. i'm certain that the head did not get damaged. i even used a cleaning cassette but no difference. can any one help me.
    Problem Solver:
  • 8 Answers
Place a dollar bill between your thumb and the heads,press gently and turn the head back and forth with the other hand...cleaned a many vcr heads this way..
Posted on Dec 17, 2008
    Novelist:
    Champion:
  • 275 Answers
Get the heads professionally cleaned. should do the trick
Posted on Dec 16, 2008
  • 36 Answers
There are 3 options that I can think of, 1 is that one of the heads on the upper drum is damaged, can see this if you look closely at each head, there should be no corners missing, it should look square, 2 is that the heads are dirty, cleaning tapes are really not that effective, if you wish to try this at your risk wet the back of a clean white business card (that has no images or writing) with ethanol or clean alchohol, place the card with the centre of the card between the lower and upper drum and carefully and slowly turn the drum clockwise by hand so that each head rubs the centre of the clean side of the card, repeat this until no more marks show.(do this only if you understand my explanation and at your own risk) 3 that one of the cables you have disconnected has not been properly seated or that the cable is damaged, check the ribbon cable connected to the head amp (silver box either lhs or rhs behind the upper drum). hope that helps.......Phil
Sony rdr vx560 dvd recorder vcr combo
Look for tape residues on the head drum (metal cilinder inside). Clean it with extreme care or use a cleaning tape. If any tape get stuck inside recently the ground shaft might be bended and it causes grainy pictures.
Oct 12, 2013 | Televison & Video
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
My VCR plays cassets perfectly, but recently I am facing recording problem. I am unable to record, I am seeing recording caption on my screen. But it is not recording.
Well I think that the the machines mechanical piece that allows you to record is broken then and needs to be fixed so we perfer DVD players and dvd disc;s instead they are better at recording and have less problems too.
Jun 18, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Door jammed open, no power
oN THIS VCR THERE IS 8SCREWS TO REMOVE THE COVER, REMOVE THE COVER CAREFULLY THEN PLUG THE CORD INTO THE WALL, THE CARRIAGE TRAY WILL ACCEPT OR REJECT THE CASSETTE. oNCE THIS PROCESS IS DONE AN THE CASSETTE IS REMOVED UNPLUG THE VCR AND REPLACE THE COVER WITH THE SCREWS
Jan 13, 2009 | Panasonic PV-V4540 VHS VCR
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
A tape is stuck in my VCR. and i cant get it out, How can I remove it? notheng
Open bottom metal cover. Rotate the belts of the motor. Cassete should unload from Spindle and reel back into the cassette. Then please open the VCR top, and you will see a belt and gearmechanism on the right side of the cassette compartment. Manually rotate the gears and the tape will slowly come out.
Jul 20, 2008 | Mitsubishi HS-U560 VHS VCR
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
My Video casset palyer is Panasonic NV-MV20 VHS VCR
Looks like the Loading cage gears Timing has got messed up. If you are worried about taking it to a Repair Shop, take it to the company service centre.
Mar 16, 2007 | Panasonic NV-MV20 VHS VCR
Why does the VCR ejects my tape?
The VHS PlayPak adaptor uses 1 AA battery. When you place your VHS-C tape into the adaptor and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink-wrap has been removed from the battery.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Televison & Video Logo
380 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
