Question about ASUS A8Js Notebook
Use of usb ports shuts down notebook
I have an ASUS A8Jc notebook which is using XP pro os... when ever i plug a printer or my mp3 player into a USB port it shuts power off to my machine. the only way to repower it is to unplug all leads and remove and re install the battery. the mouse will work fine. is this a software problem or worse?
  • relentlessbo Dec 22, 2008
    my dell notebook does the same thing when trying to print, upload pictures from my digital camera or using my memory stick.
  • 829 Answers
Is there any data in the USB , I suppose it can be a virus , can you Format the USB stick and then insert to the laptop.
Posted on Dec 15, 2008
I just bought a Sony NWZ E354 mp3 player. When plugged into my usb front main port, computer sees it as MTP device but disables it. I' running Win XP Pro and WMP 11. Take same player and its...
I upgraded my usb drivers -- I have windows xp pro -- i think they use all the same -- I used Realtek USB 2.0 card reader drivers. ( ) plugged it in (NOT in the front, but the back)_ & it recognized it after going to start, computer as "walkman" -- did a right click explore & all the data/music was still on the hard drive. then it showed on the walkman that it was charging & the battery was dead. i was previously using an AC usb adapter (plug in the wall) & it didn't seem to be charging it correctly -- so the computer works out for me & will only use that from now on -- fully operational.
Jul 14, 2011 | Sony Ericsson Audio Players & Recorders
My computer says the USB port connected to my mp3 is drawing too much power and has shut down the USB port. How do I get around this? I have a MacBook Pro.
It look that your player is drawing too much current from your Macbook Pro: it is rather unusual nowadays but does happen even with some USB external 2.5in drives!
1) Buy a USB Power Adapter Y cable that plugs into 2 usb ports on your Computer an thus allows double the current (shop around as they are expensive on Amazon but pretty cheap on Ebay)
2) Plug your player via a 'Powered' USB Hub that can provide higher current (from its 'own AC/DC power pack') to each USB port on the Hub
Hioe it helps!
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
A Pop-Up always says me New Hardware MTP Device I don't want to see it. My OS: Windows XP professional SP 3
Do you keep inserting the Mp3 into a different USB port? Try using the back panel USB ports instead of the ones in the front of your case, and always use the same.
Oct 27, 2009 | Coby MPC-848 MP3 Player
Windows XP Pro will not recognize Coby MP3 player.
could be one of two possibilities. one something is wrong the usb wire or two, the player is locked. mine did the same thing when i first got it. i unlocked it and it worked
Jan 05, 2009 | Coby MPC-683 MP3 Player
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Formatting the device will not solve the boot error you are getting..thats a firmware problem..get the firmware update and that should solve the problem you are having..
Jan 24, 2008 | RCA OPAL M4001 MP3 Player
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
The Mp3 player may need a powered USB2 supply and not a peripheral powered supply. The only reason your other usb ports may not work is that the controllers need re-installing or they are not enabled; see this post:-
Nov 29, 2006 | Averatec 3200 Notebook
ASUS A8Js Notebook Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
