Question about Sony KP-57WS500 57" Rear Projection Television
Screen protector broken
Screen protector is broken and now it has affected viewing but throws nice pretty green and red light on the wall behind the viewing area any ideas on where one can pick up this protector or piece
  • 4,234 Answers
The protective screen is part # 409088101 and is available from tritronicsinc.com for $103.01
Dan
Posted on Dec 15, 2008
I have a panasonic flat screen monitor that worked well untill recently. It switches on for a second with the green light on then it switches off and the red light starts blinking. Please advise.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 01, 2013 | Panasonic PT-51G53 51" Rear Projection...
TV projects red blue and green lights onto wall
If you project it on a distant wall the convergence will be way off since the tv was designed to project it just a few feet at most onto the screen. So you would have to do some manual adjusting... As for the screens you need the two layers...if one is broken get a broken model like yours on Craigslist for parts or check with www.TvRepairKits.com for screens...they are stocking some
May 20, 2013 | Toshiba 57H83 57" Rear Projection HDTV
My RCA L42FHD37YXII has dark green and light gray vertical stripes on left side of tv it is on all connections
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
Sep 30, 2012 | RCA L42FHD37 42 in. LCD HDTV
MY SCREEN IS TOO DARK, YOU CAN HELP ME
  1. Remove any screen protectors or cases you have on, that could possibly affect your view.
  2. Go to Settings>Display>Brightness and adjust the setting to a higher value.
  3. Ensure the ambient light sensor near the speaker is unobstructed.
Jul 01, 2011 | Apple iPhone 3G
HP PSC 2355 does not "boot up".
Is it connected directly to the wall socket for the power supply or thrugh a surge protector.. if its through surge protector try connecting directly to the wall jack ..
Oct 19, 2009 | HP PSC 2355 All-In-One InkJet Printer
Bluish green screen on dell laptop
It might be that your red pin is bent out of shape. Please make sure ALL pins on BOTH ends are straight, and none are broken or missing. Also, make sure that they are firmly secure.
Jul 03, 2009 | Dell E176FP 17" LCD Monitor
Broken plexiglass tv screen
crack in the screen? well the screen is the end result of small light mirrors and a color wheel that can project up to and more than 16 million colors ...... so that screen is very important to recieving these light shows and making a nice picture. a crack ... yes you will see all kinds of crazy things... and even probably on your wall behind you.
need new screen and problably a nice check on alignment.
Oct 24, 2008 | Samsung DLP HL-P5663W 56" TV
Sidekick 3 Problem
okay i have a sidekick 3 as well and what you need to do is put the paper clip in the hole again and hold the power button at the same time for approximately 3 seconds. This is a hard reset. Now the bad part is that this will reset all of your data back to factory default. If you need further assistance or this does not work click the ask me button next to my name and we can work on it from there. Thanks.
Aug 25, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Reset Surge Protector
You can fix it by doing this. but first you need to make sure you leave your house for at least 4 hours so you don't have to be hearing that frigging noise, IT CAN BE DONE! i fixed it.
my unit would start beeping as soon as I plug it in wall, and red light come on, the software is telling me the battery is unplugged
this is what i did in order.
1. unplug all cords, connected to the unit, and power cord to the wall.
2. hold the power button
3. still holding the power button, Connect it to wall. (red light would be on but no beep)
4. I watched TV for 6 hours, red light still flashing
5. disconnect from wall
6 connect back to wall
I heard the unit click one time and green light came on, is charging now....
Jan 27, 2008 | Computers & Internet
Cobwebbs between the screen and the screen protector
Hi pykeman,
I have successfully used a feather duster taped to a vacuum cleaner extension tube with duct tape. Remove the back panel of your projection television, then remove the the rectangular panel near the top over the chassis where the cabinet exposes the inside screen area. You will see the red, green, and blue CRT lenses. Insert the feather duster through this rectangular opening and sweep your cob webs away from the screen. Works for me every time.
Regards,
MyTvGuy
Jan 19, 2008 | Philips 46PP9302 46" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
