Question about Makita 9 Hp 4,300 Watt Portable Generator #G4300L
Makita Generator suddenly stops has gas
Generator was working well for hours suddenly heard a pop and it stopped. Has gas
  • Carl Gehrke
    Carl Gehrke May 11, 2010
    You should check for spark next as that's easy to do. It sounds a little like you've lost a valve lifter or gotten something amiss in the valve train. This is an OHV engine right?
    Carl
  • 211 Answers
Hi
Hi See if the gas tank cap vent is clogged,remove the cap and check the gasket in it.Check the flyweel key(not to be sheared) and the condenser( not to be defective).The ignition points(not to be burned).Check the oil in the crankcase(pay attention to the low-oil-level shutoff sistem (if there is one).Check the fuel lines and filter.Check the muffler(not to be clogged).Check the plug wires and make sure is securely attached at the sparkplug.Check the cable and linkage.
best regards savumihai71
Posted on Dec 20, 2008
What would cause popping when I turn it off?
a shredding fan belt?
why not get the car checked out.??? buy a SHOP
you shut the engine off, and when you do, that it coasts to a stop
and did the noise come from the engine bay? and did the noise happen as engine was coasting to its natural stall or after that?
noises that happen, not moving are easy to find. so
get a competent mech, to find it. it be easy for them.
Oct 30, 2014 | Hyundai Motor 2004 Accent
Table saw starts for 2 second and stops
if it is electrical u might wont to check the battery if it is gas u might wont to chek the oil or the gas if it is gas
Jun 03, 2013 | Makita 2703 10" Table Saw, Electric Brake
I have a Kohler whole house Generator that starts and works fine but stops after a hour or two. It restarts fine but again stops after an hour. Oil is good, load is not excessive, propane fuel is...
possible sensors to check are
overheat sensor for the coolamt
time run sensor if fitted
oil pressure sensor
loose wiring connections
possible icing of the gas regulator because if excessive gas flow requirement
have a gas fitter check the air mixture settings for the engine
Jan 15, 2018 | Electrical Supplies
Makita JR3000V stopped working
I would have checked the cord first. Cords are a high failure part because they always get bent and pulled and such. Some versions of the jr3000v had problems with field wires breaking right at the field terminal.
Mar 05, 2012 | Makita Saws
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
Aug 30, 2009 | Makita Hammering
1990 Grand Am won't take fuel after loud "pop"
when you turn the switch on listen in the fuel tank to see if the fuel pump comes on
Jun 29, 2009 | 1990 Pontiac Grand Am
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita 9 Hp 4,300 Watt Portable Generator #G4300L Logo
264 people viewed this question
Top Makita Electrical Supplies Experts
Craig Butler
Craig Butler
obsteiner
Tom Chichester
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
