FixYa.com
Tags:
Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
The fan on my space heater (small appliance -...
By Rachel007 - usenet poster
The fan on my space heater (small appliance - honeywell #hz-2300)came off. I'd like to open the unit to re-attach the fan. The screw heads look like triangles. Regular and phillips screwdrivers do nothing. Is there a special tool / screwdriver I can buy?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Gary10
Gary10 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The screws you have encountered are provided to prevent entry into the unit and were invented by Admiral Electronics about 30 years ago. They are a real pain.
You can get an adaptor that will fit a 1/4" spin-tight socket wrench at most electronic houses and even some hardware stores.
My advice is to pick up some standard screws from the hardware store and replace these things if you intend to work on the unit.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Conair 157R Ceramic Compact Turbo Heater Frontgate 18373 Heater Honeywell HZ614 QuickHeat Baseboard Heater Honeywell HZ708 Oil Filled Radiator Heater Honeywell HZ780 Oil Filled Radiator Heater Honeywell (7215B120H) Heater Honeywell HZ2110 Utility Heater
Can you Help with these Heaters problems?
Heaters
Marivn 2060 Quartz Heater...
Well, I've already entered this... Answer This...
Heaters
Honeywell HZ450 Switch needed
Where can I get a replacement... Answer This...
Heaters
gmpn100-4 goodman heater ac
my ac unit fan works on the... Answer This...
Heaters
pyrox 303 gas heater
I have been given a Pyrox 303... Answer This...
Reddy Heater RLP100 Portable Forced Air...
COMFORT GLOW PROPANE HEATER,...
just had the propane tank... Answer This...
Repair Service
Find Heater Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
