Question about Canon imageRUNNER 5000 Copier
Help me.....faster.... Canon Image Runner 5000... it's have Error 350-3000.. I have change Hard Disk, DC Control, Main Control, Reader Control,HVT, but the machine Still Have the same Error... I have try to repair it for 3 months.....
  • Everett Lin May 11, 2010
    Dear sir; I like try to help you,but the error code you give to us , I can not find in the manual, would you submit correct code, that will be great helpful, thank you, HAVE A HAPPY HOLIDAY !!!
    Sniper:
  • 57 Answers
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Posted on Dec 25, 2008
Symptom E350 Error Code Description This error code concerns the soft counter and is displayed when the serial number PCB is faulty. It is unable to be cleared in service mode. Cause Serial number PCB is faulty. Field Remedy Replace the serial number PCB with a new one.
In addition, upgrading of the system software is required if it is under Ver.18.01 for iR5000/iR6000/iR5110/iR6010/iR5000S/iR5000N.
<Note>
The serial number PCB is not assigned as a service part, as same as the counter memory PCB. Please contact a division handling this issue for procurement.
Posted on Jan 06, 2009
    New Friend:
Ir 5000 erroe code 804 000 plz help me
Posted on Nov 24, 2015
  • 3 Answers
AR-516 photocopier sharp. Said call for service, help me solutions. Thank you
Posted on Jan 16, 2012
Canon copier ir2016 and the print page is white or no image just blank page displayed
Sir
Pl. check the drum unit contact points up HVT card. Replace HVT card. (Assumed you have good drum unit). Check the toner throw at developer mag roller.
Thanks.
Dec 18, 2014 | Canon Office Equipment & Supplies
Canon image runner 6570 error code E000732-0001
something wrong in DC Control to Scanner .
- check the scanner
- check the cables and socket between them
- or change the DC control
Apr 21, 2011 | Canon IMAGERUNNER 6570 Copier
I have an error 00315-00d...can u help me to fix it...in canon image runner 5000...thanks a lot
hi;
you mean E00315-000d-00
this error code appears when there is a codec error the solution is :
1) replace the SDRAM
or
2) replace the HDD
or
3) replace the main controoler board
Oct 04, 2010 | Canon imageRUNNER 5000 Copier
We have about 18 Canon Image runner 5000 copy machines which we have sold. We would like to re-format the hard drives and reload with copier software.
Do you have experiance with canon software upload and disk issues?
To upload system software, system language and format you need canon's service support tool and PC with Centronic interface.
There is catch for HDD type and you need to write the HDD's serial number in Service support tool database ( THESE IS ONLY DONE IF YOU CHANGE THE HDD WITH NOT CANON ONE ).
For more help write me on emma.servis@gmail.com
Hope that helps!
Aug 18, 2010 | Canon imageRUNNER 5000 Copier
We have e249 code on start
The memory elements on the PCB are not connected, have poor contact, or
are faulty.
Description
0001 An error has occurred in the course of a read/write check of the
memory on the IP memory PCB.
0002 An error has occurred in the course of a read/write check of the
memory on the ED board.
Try to reconnect all conectors on dc controller pcb.
Apr 22, 2010 | Canon imageRUNNER 5000 Copier
Sysrem error E245
E24x usually relate to main board errors.
Comms failure between DC Controller and main Board.
EEPROM failure
Control panel PCB failure
Something like that.
Nov 28, 2009 | Canon Image Runner 1630 Copier Copier
Code de panne E000584-0003 for canon image runner
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty.
For the reset : COPIER-FUNCTION-CLEAR-ERR.
Sep 01, 2009 | Canon Office Equipment & Supplies
Help quick
The main controller PCB has detected an error in the communication
between the DC controller PCB and the main controller PCB.
try to reconnect all conectors on your machine, check for toner dust on them, realese all wire holders, check the wires,...
Dec 13, 2008 | Riso RZ220 Duplicator
Canon imageRUNNER 5000 Copier Logo
556 people viewed this question
old marine
old marine
