Question about Canon PIXMA MP150 All-In-One InkJet Printer
Too much ink
I refilled my colour inkjet with too much ink. the result is the pictures are very dark. instead of pink the colour is close to olive green, sometimes darker. i refilled too much cyan. please help. bright colours turn out to be dark and moody.
  • 81 Answers
Hi, sounds like the colours are mixing because of the overfill. You can try this , but may take a while.
Get some tissues (around 6) fold them in half and put on the table. Keep dabbing your ink cartridge on the tissues in different places until you can see the 3 different colours clearly. This can take a while, but generally does work...
Posted on Dec 16, 2008
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Jan 10, 2018 | Panasonic TX-36PF10 TV
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
Canon S520 printer colours not correct
i think its time you replace/refill that ink cartridge. some of the colors must have run out.
Sep 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Not printing out true colors
My guess is you either have the wrong cartridges or your cartridges need replacing.
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
Excessive Ink & dark band on nozzle check
hi, are you using cis ( continuous ink system ) system or refill?
if cis try place the inks lower than printer if refil try repressure them ( open the plug hole - press the cartridge on the side then close them)
if you are using original ( not likely ) replace them..
Mar 23, 2009 | Epson Stylus Pro 9800 InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
Feb 09, 2008 | Epson Stylus RX500 All-In-One InkJet...
Canon all in one printer refill ink cartridges
i have just filled my mx 310 with the jet tec refills as instructed....but do not insert the rubber bungs...instead put some celotape over the filling holes... then with a needle...pierce the celotape where the hole is( pin *****).... this set up is now able to breathe as originally designrd. Mine prints fine now this has been done (trial and error), but i might try better quality ink next fill. Its also wise to use glossy paper 230gsm or over for good results.
GOOD LUCK.
Dec 20, 2007 | Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
55 people viewed this question
old marine
old marine
