Question about Gaggia Classic Espresso Machine
Parts needed Can anyone tell me where I can get a pod adaptor for the Gaggia classic? I find that the single shot filter basket is too deep to allow the pod to be pressed down firmly enough and I know I have seen these previously on my ex's machine. Also does anyone know where I can get a new outlet/overflow pipe (the metal one that sits on the left side in front of the water tank)? I live in Sydney. Thanks, Lucy
  • Gaggia Expert
  • 109 Answers
Contact Shriro located in NSW
Posted on Feb 22, 2010
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
Gaggia Classic. Completely disassembled and cleaned. Water path clear. Great water flow thru the group head and filter holder "with no coffee". With coffee or pod in filter; takes 3-5 minutes to pour a...
Hi
If you don't have the pressure it may be the pump. Vibration pump Gaggia Rancillio or you have a blockage in the solenoid. For solenoid , partially remove 1 solenoid screw and try to make a coffee - water will pour from solenoid and hopefully clear the blockage .
Mar 08, 2018 | Gaggia 16002 Espresso Machine
I have a Baby Gaggia, several years old. I buy IZZO ESE pods, which I understand should fit the holder. They do not in that a pod sits loose in the holder, with a margin round the edge between it and the...
Please try the following:
  • Remove the portafilter and activate the brew switch. Water should stream out of the shower screen. If not you need to clean the group components, or the machine is broken.
    To clean the group components, remove the center screw. The screen should drop down, the dispersion disk may be stuck, you can pry it loose with a flat head screw driver. Soak both of these in a descaling solution.
  • With the group components removed (as above) try brewing, water should stream out of a single hole. If not, you may have a faulty pump, or seals.
  • If water streams out normally, be sure that you are using the single espresso basket. This is the smaller basket that snaps into the portafilter, and has sort of a tulip shape.
  • Your group head gasket may be worn, and will need to be replaced. These need replacement ever 6 months to 12 months, and need to replaced even if the machine is rarely used, because they are made from natural rubber that dries out.
    Replacements can be found at many retailers online, a few are:
    espressocare.com, espressoparts.com, and seattlecoffeegear.com
Mar 02, 2011 | Gaggia Baby Espresso Machine
I am using my new silvia with the ese pod adapter with illy pods. When I press the coffee dispense button with a pod in place, coffee begins to come out of the right orifice, then after a few seconds it...
"leaks noisily from what appears to be the contact between the grouphead and portafilter"
* Leaks from top of portafilter and group head are caused by poor sealing at head gasket.
* wipe top lip of portafilter before inserting into group.
* check if group is clear of coffee grounds, paper bits, tissue, dry crud. Use a head cleaning brush (tooth brush works) and wipe group clean (do not use screwdriver to scrape!)
* Make sure when inserting portafilter it is seated properly. (check your manual for procedure) Note the position of the portafilter handle if it's in the right position AFTER you tighten it. Is it far to the left? or stuck and barely hangs on to group?
* Barely hanging on to group? Check if pod is too big. Note; you can't double shot or use 2 pods in a single pod basket! Make two separate shots for a double.
* Handle tightens but slips off group or still leaks when pulling shot? Worn out or missing gasket. Gaskets are made of rubber and can crack, drop out, or pit. You will need to have the gasket replaced. Check with vendor or MFR for service/parts.
* Make sure you have the correct portafilter. Many look the same and may even fit but when making fine adjustments or critical shots they don't work right. Check manual or vendor for confirmation.
* Make sure you have the correct basket. The portafilters may have different baskets or cups that can be inserted. Many have special uses that can affect the pull of a shot. Fewer holes causes slower flow and longer brew time. Many holes gives a weaker shot but smoother less bitter taste. There is a blank basket that has no holes which is used for backflushing and cleaning of the group. Check your manual or vendor for which basket you should be using. Odds are that you have a standard basket ment for ground coffee and not pods. (you can remove the coffee from the pod but it will be messy.) Ask for the optional 'POD' basket insert.
* Finally if everything checks out and your still having leaks then your machine needs service as the group head or valve needs replacement. Call your vendor or MFR direct.
Aloha! ukeboy57 (youtube)
P.S. Looking back at my service with pod conversions, I've found that most if not all pro-machines don't really like the pod adapters. Sure it will work but shots are weak and poor. Pods really like a very tight fit with a very small portafilter basket(chamber) I mean like the size of a soup spoon! They like very slow and very hot water pumped with a vibration type pump to extract all the essence from the paper filtered coffee. Illy is an excellent coffee pod with a very rich aroma and good creme. The best for them (pods) are the dedicated pod machines (won't do ground coffee, only pods). If you must use a pro semi-automatic machine then I would suggest adding a port constrictor to the portafilter output. There may be a third party supplier that has a compatible adapter for your brand. I've come across some of these very extreme tools for the elites coffee affectionato. It restricts the flow at the output thus causing the hot water to brew longer and at a higher pressure to force the hot water and steam into each coffee grain. (think pressure cooker) Some of the better ones are adjustable. But note that these will need daily or cleaning after each use as these restrictors have very tiny holes which clog unless flushed after each use. Good luck 9on your pursuit of the perfect cup!)
Jan 17, 2018 | Rancilio Silvia Espresso Machine
Hi i have agaggia classic and its portofilter is non pressurized do i have to buy something to put inside because it has two holes and a straight line like you can slot something inside i cant put coffee...
Yes all you require is a single or double filter basket. This just pops into place and you put your ground coffee into it and away you go.
If you need any further assistance or would like to purchase any of these baskets then please get in touch with myself (David) at domesticespresso@live.com
All the best
Mr La Pavoni
Jun 02, 2010 | Gaggia Classic Espresso Machine
Regarding the single shot pod and filter
the machine might or might not have had the pod filter based on manufacturing date. If you did not have one it can be purchased on Breville USA web site for $10.
Jan 22, 2009 | Breville Die Cast 800ESXL Espresso Machine
Pod filter basket
I can not this machine, sorry
I do service on Saeco, Kenwood, LaPavoni, Spidem, Cuisinart, Breville.
Have a nice day
/Mirran
Oct 04, 2008 | Nemox Caffe NEM 205 Espresso Machine
Are you tamping the coffee at all?
The ground coffee needs to be compressed, using a tamper, to form a hard puck that the water will then get squeezed through.
This has already happened to the ese pods so needs to be replicated in the portafilter when you place freshly ground coffee into it.
The plastic tampers provided with your machine are not fit for purpose and a metal tamper is highly recommended. The base of the tamper should be 58mm
Mar 30, 2008 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
192 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
