Question about Canon MF8180C Color Laser MFC Printer
My scan is not prorerly working? Is coming an error "plz select the another application,this application is not found"
  • P. Thomas
    P. Thomas May 11, 2010
    this always works better when you supply a model number.
    Novelist:
  • 59 Answers
Hi dpknarwal,
In case anyone else would like to assist as well, please note that the model is Canon 8180C - on FixYa all questions are categorized according to the product model, so if it's not in the question, it's in the header above the question.
Now, to answer your question, have you installed the software that came with the machine? If not, do so now. If you have, try uninstalling it and re-installing it. Also make sure that the Canon is connected to your computer. Try unplugging the cable and plugging it back in. The instructions for installing the software are in the in the software guide, which you can find at this web address:
http://gdlp01.c-wss.com/gds/0900008039/imageClass_MF8180c_Software_Guide_EN.pdf
To scan on this machine, press [my scan is not prorerly - moz-screenshot.jpgScan], then [B&W Start] or [Color Start]. If this is the first time you've tried scanning with this machine, you may need to select a program to work with the scanner. Try selecting moz-screenshot-2.jpgMF Toolbox ver. 4.9 (or whatever version you have).
The other option is to use your computer to scan the document. Go to Start > Programs > Accessories > Scanner and Camera Wizard. If it finds the Canon, it will scan the document. If not, then the software and/or driver is not installed correctly. You can also perform this function with other programs on your computer, such as Paint (choose File > From Scanner or Camera...) or even Microsoft Word (choose Insert > Picture > From Scanner or Camera...) If the program finds your scanner, it will import the image. If it doesn't, then the software and/or driver is not installed correctly.
For your reference, the basic User's Guide for your Canon can be viewed at the following web address:
http://gdlp01.c-wss.com/gds/0900008008/imageClass_MF8180c_Basic_Guide_EN.pdf
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 16, 2008
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Werfault.exe -application error\r\n
You can try to disable this service by following the below steps:
Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu.
Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu.
Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows.
Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, y
ou should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
Jun 10, 2010 | Dell Dimension 4400 PC Desktop
Printer has stopped scanning, error message cannot download application data
Mine does this too.
When the error comes up press the red X cancel button then select the computer name again and press the tick button it should then find the application list ok.
Apr 23, 2010 | Lexmark X4550 InkJet Printer
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
When installing the 6310 all in one printer, at a certain point I get the following message: "The application HPIO Trap Monitor quit unexpectedly. Mac OSX and other applications are not affected. Click...
There are two ways for install the Scanner using only "the driver" and using "HP Photosmart Studio Includes Support for Mac OS X v10.3, v10.4 and v10.5 (Leopard)" using the driver not include IRIS OCR software only the driver to scan and thats why say "An OCR error ocurred, couldn't create file". Installing the HP Photosmart Studio fix the problem.
If fixed the problem visit my page www.richardsite.com.mx
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Jul 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon MF8180C Color Laser MFC Printer Logo
234 people viewed this question
old marine
old marine
