Question about Panasonic Televison & Video
My TV model CT-36HL42CF,the power switch (on-off) doesn't work
    Novelist:
    Champion:
  • 203 Answers
Hate to disagree, but the tech asst. dept. said to upgrade to a larger fuse on certain models of flat screen crt 32 &36 inch models. We factory servicers first tried a 6.5 amp but a few came back, so we went to a 7 amp and that solved it. Those certain models draw alot of current to run the tube and it sometimes peaks very close to the original fuse's value. I agree not to go to any higher amperage but 7/10ths of an amp will stil provide safety within the set. Good luck, Russmann.
Posted on Dec 18, 2008
    President:
  • 1,284 Answers
The original fuse in a Panasonic is a 6.3 AMP fuse. NEVER EVER use a larger fuse then the set is designed for. The thermistor is bad but, please only use a 6.3 amp fuse. Using a 7 AMP fuse as Patagonia suggested is downright a possible hazzard!
  • Don
    Don Dec 18, 2008
    I have read NO factory updates for any Panasonic model that states to use a larger fuse. The fuse goes at turn on due to the inrush current drawn by the thermistor/degauser on these units. The same happens with some Sony and Samsung CRT sets. Now changing the thermistor to a slightly higher resistance is the better choice so the degauser wont pull so much current at turn on. This is the ONLY fix that should be done period. Now if you want to take the chance and use a larger fuse on your repairs then do it and take the responsibility otherwise never advise the novice to re-engineer his/hers TV and possibly risk the chance of a fire!
    Sergeant:
  • 250 Answers
You will need to have the switch replaced. If you are a handyman, it is possible to do it yourself It only involves un-soldering four contact points and re-soldering in the new switch. But be sure you use the same type of switch, or you may not be able to make the replacement one fit into the holes on the PC board. Don't forget to rate this answer.
Posted on Dec 17, 2008
  • 3 Answers
Is the button broken? More likely, the thermistor and main fuse need replaced. The fuse should be upgraded to a 7 amp GMA.
Posted on Dec 16, 2008
Will power up only after the power cord unplugged and plugged back in to the outlet. Then shuts back off again. CT-36HL42CF.
High voltage too high going into xray protection. Check the collector of the horizontal output transistor for 130v dc.
Oct 10, 2011 | Panasonic CT-36HL42 36" TV
The tv doesn't turn on. checked power and both dvd and cable box work.
Obviously you must make sure the power is plugged in.
You should also try to get up and manually operate the power
switch on the thing, to be sure some of the 'StUpId' things aren't the actual problems.
I could be the remote!
When all of this is for sure, call a tech. Its big and dangerous for you to get into the back of.
If you were in VB you could ask me.
PLEASE RATE THIS ANSWER
Aug 29, 2011 | Panasonic CT-32E13 32" TV
Panasonic hdtv 1080i CT-36HX41E..Can you hook up a PC to the tv for the monitor?
You can connect this to your computer if you have an S-Video output on your computer. This is the only supported connection on your TV. This model doesn't have a VGA, DVI, or HDMI port.
Hope that helps!
Jul 19, 2011 | Panasonic CT-32HX40 32" TV
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
Have a TV Panasonic CT-36HL42CF for repair, I change the horizontal ouput 2SD5612 (was short) after a week the horizontal was short again. looking for a solution
You must replace the component that killed the transistor in the first place!
Replace the tuning capacitor in parrallel with the transistor. If it's blue it will be O/c or if yellow low value.
Jan 03, 2011 | Panasonic Televison & Video
How to replace on/off power switch on TEAC CT-M343 TV
the switches have a small spring that helps click the button to stay on or off its common for the spring to snap if you have another switch just pull it appart and replace as you undo it of not you can jam the switch on with a slide of paper or match stick then turn on off at wall or put a lighting switch in line with the power cord such as from a lamp
Apr 21, 2010 | Televison & Video
Panasonic tv 36 ' won't turn on ct-36hl42cf
check the fuse and power supply also the horizontal phase
Aug 22, 2009 | Televison & Video
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
same trouble ,the tree pronged square chip that you mension which is called horizontal transistor is busted again. try to check the plyback of your tv .maybe that parts have a problem.
Sep 29, 2008 | Panasonic CT-36HL43 36" TV
Televison & Video Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
