Question about Rockford Fosgate Power 360.2 Car Audio Amplifier
Rockford Fosgate Punch 360.2
Using the amp bridged to a 4 ohm load. The speaker wires touched + to - and the amp began to play inconsistently then quit playing altogether. The amp also became unusually hot. Now the amp does not play but does turn on.
  • Anonymous Mar 29, 2014
    wiring ohm loads to amp
  • 62 Answers
If the wires were touching then the amp overworked itself into a early grave..What happends when they touch is the amp goes from seeing a 4 ohm load to seeing a 0 ohm load. You can imagine why this would be bad for a amp...usually the amp should shut off to protect from damage and I would assume that Rockford would. Right now im having a similar problem..I suggest your call rockford and ask to talk to a technical advisor ( the name escapes me) and ask him what he thinks.
Posted on Mar 25, 2007
I have a rockford fosgate t1500 amplifier and two 12"kicker L5's duel voice coil. the subs are wired together as one. they worked for about half an hour. now the amp and head unit comes on but no...
This amp is rated at 200 watts when run at 4 ohm load when in bridged mode (mono).You will need to check the measurement of the load at the amp's positive and negative location where it meets the speakers. You are actually going to need to measure the load of the speakers on the amp. If it ran too low of a load, meaning less than 4 ohms, there is a good possibility that the amp overheated and damaged some internal components due to not enough resistance. Some of their amps have internal fuses that can be replaced. It may be time to visit a diagnostic shop.
Bruce
May 04, 2011 | Rockford Fosgate Punch 201S Car Audio...
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
Wiring for 2 subs for max performance
This amp is rated at 500 watts into a 4 ohm load bridged mono or 250 watts x 2 into 2 ohm load stereo. Do not go below that impedance in either case. The amp was meant to dissipate a certain amount of power, driving it to hard will lead to damage. Your speakers look like they are dual voice coils @ 4 ohms each. To get the max power while still saving your subs would be to parallel the voice coils on each woofer then run them in stereo with your amp. Stereo 2 ohm is 250 watts per speaker.
Dec 14, 2009 | Rockford Fosgate Punch 501S Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Amplifier loads
    Hello ronnieyannon,
    A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
    I'd wire them the way you have them wired.
    Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
    Hope this helps.
    Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
    How to bridge a punch 3001 car amp
    You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
    Feb 24, 2009 | Rockford Fosgate Audio Players & Recorders
    Rockford Punch HE2 wiring question.
    if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
    Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
    Rockford fosgate punch 700s gets very hot
    Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
    Does the amp get hot?
    If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
    Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
    Sub woofer wiring
    If you have a 500a2 and two 4 ohm single voice coil speakers, you have only one option. Connect one speaker to each channel.
    Dec 30, 2007 | Rockford Fosgate Punch 500a2 Car Audio...
    Rockford Fosgate 800a2 To 2 SVC 2ohm subs
    Ok.. Bridge the two sub into 4ohm than bridge to amp.
    So. this how it goes.
    sub1 + -
    to      | |
    sub2 - +
    =      4ohm
               From Sub
                    Two
    amp (L) - + (R)- +
    This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
    Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
    Rockford Fosgate Power 360.2 Car Audio Amplifier Logo
    421 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    seankane89
    Level 1 Expert
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
