Question about Cameras
My Vu Me won't turn on!
I replaced the batteries, I read the booklet, I tried everything in the book! It still won't open!!!
  • 1 more comment
  • MGMORG Dec 20, 2008
    I bought a football and a soccer ball the soccer ball works and the football turned on for a second and now I can't get it back on. I purchased them both at a linens and things and they are now out of business.
  • Anonymous Dec 21, 2008
    I've gone through two ornaments so far and have had the same issue. One stopped working after a few days, the other wouldn't work right out of the package.
  • springer_jen Dec 26, 2008
    It kept giving me error messages when I first installed it. When I finally got it to load it seemed to be working. It let me transfer all of the files but now it won't turn on...
Replace knock sensor on 98 Altima. In order to reach the screw, I removed the fuel rail from atop of the engine. I put new sensor and in and out rail line on. Started car. Car won’t start. It’s not a...
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 21, 2018 | Nissan Altima Cars & Trucks
I tried to check the fuses of my fords windstar for the right window, cause it was not working. But then , when start my windstar 95, it won't start. when turn on, nothing i wrong, but when to turn it...
Make sure battery has a full charge. Use a digital multimeter across battery posts, everything off, what is the reading? The generic spec for a full charge is around 12.6 volts. Note the reading. Leave the leads touching the battery posts, have helper turn key to crank, how much does the reading drop? Usually it shouldn't drop below 9.6 volts or there about. If it drops to zero, try charging the battery. Check battery cables. Did you try jumper cables to see if it would crank?
Jan 29, 2018 | 1995 Ford Windstar
LG Vu Battery Cover
This is a device issue. You will need to contact your service provider for replacement options!
Mar 04, 2010 | LG Vu CU920 Cellular Phone
LG VU won't turn on with SIM card after getting wet.
Go to your cell phone store and have them try another SIM card.
ATT replaced my SIM for free.
Aug 08, 2009 | LG Vu CU920 Cellular Phone
Smartchip not reading???
if you take sim and battery out for about 15-20 minutes and boot up your phone, you should be fine, i talked to my stepdad, computer freak, he said it could be caused from me not ever shutting my phone off and it just getting hot
Aug 04, 2009 | LG Vu CU920 Cellular Phone
My lg vu wont call people and if it does they cant hear me. i've already checked the battery and the sim card and tried turning it off and on. How do i fix it?
well its not the battery and the sim. im a technician and u need is to replace its mouth piece inside/ or you can try opening ur lc vu and try to clean the surface where the mouth piece is connected.. clean it with an eraser (i.e. pencil eraser) because it will remove the dirt/stain thats prventing the signal of ur mouth piece to your phone. and for this matter I am 95-99% sure.
Aug 01, 2009 | LG Vu CU920 Cellular Phone
New vu just blinks off and on, will not show its charging just blinks
Try removing the battery and SIM card and let it sit for 5-10 minutes. Put everything back and start the phone again. Make sure battery and card are in properly.
Jul 20, 2009 | LG Vu CU920 Cellular Phone
I dropped my Lg vu cu920 in the swimming pool, and I immediately took out the battery and let it dry out, tried the bag of rice, now when I put the battery on the screen says "emergency download" what the...
This same thing happened to me, except it was a toilet. My phone gave me the same message for about a day, but I put it under a reading lamp, battery out too, and let it sit for the night. When I turned it on in the morning it worked okay.
Jun 28, 2009 | LG Vu CU920 Cellular Phone
Can i have the phone speak the text message?
i do not think the phone reads the text messages out loud. you can say someones name in ur address book but i don't think it has that setting you want for your lg Vu
hope this helps
Jun 06, 2009 | LG Vu CU920 Cellular Phone
Cameras Logo
145 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
