Question about Ricoh Aficio 450 Copier
Aficio 450e installation
I've tried to add the Aficio 450e printer to the pc (Windows XP) using the LTI port but there seems to be no communication between the pc and the printer. Also tried by adding it by creating a TCP/IP port but it does not seem to response when i sent a test page for print. Strange thing is there is response when i try to ping it. Does anyone have any idea how i can add this printer ???
  • sendo_13 Dec 18, 2008
    Done installing it with a parallel cable but now trying to do it with a LAN cable as he wants me to install it on more computers in case d one it is attached to fails. Anyone who knows the basics of a network printer installation pls give me a step by step guide. I just wanna make sure i did it right. Do I need to reboot the printer after i've installed the driver to the pc ?
  • Tim Babcock
    Tim Babcock May 11, 2010
    What type of cable are you using to connect the copier with? A parallel cable or an ethernet cable?
  • Ricoh Master
  • 2,794 Answers
First find out the gateway address of your router. Then pick an address for it. If the gateway has an address of 192.168.0.1 then the ip address could be 192.168.0.100. Press the user tools/counter button. Look for IP address in the settings. Usually it is in the interface section. Once that is assigned you don't have to restart the copier.
Once you get that done, then you have to assign an IP address to each machine by creating a port. On the computer that you installled the parallel printer to is a good one to start with. Are you using Vista or Windows XP on your computers?
Posted on Dec 18, 2008
RICOH Aficio 3045 HELP!!! Necessary
If you have used various computers with different OS's and you still cannot get any to recognize the printer, then it would appear that the printer electronics are fubar.
U might check with Ricoh but ......................
Sep 17, 2016 | Ricoh Aficio Office Equipment & Supplies
What do I do ? i got code SC981-00 0N RICOH 450e
[SC981] - poor connection between BICU and MSU (HDD controller)[
[SC981]- poor connection bet
Aug 20, 2014 | Ricoh Aficio 450e Black and White Copier
How do I setup a Ricoh Aficio MP C2800, for clients to print from? I have connected the printer to an ADSL router, to which the users communicate over wirelessly. The printer have been provided with a...
Try setting the printer up this way, go to Add a Printer, Add a local printer, select create a new port. Choose Standard TCP/IP Port. Input the static IP address. Next choose Standard. Select the driver for your printer
Sep 01, 2011 | Ricoh Computers & Internet
We have a Savin 9945DPE that needed a new hard drive. We run a windows based Small Business Exchange Server 2003 and XP operating system on clients. Anyway after the new hard drive was installed we cannot...
do not use the dhcp for the ip for the printer. set it to static. make sure the first pc you set the driver from is set to local printer as the default. make these changes and let me know.
Jan 02, 2010 | Ricoh Aficio 450e Laser Printer
Can't figure out how to open the UDP port number 427
Don't know why this becomes an issue with these type of HP printers but i think ive worked a way around it...
Heres how you do it: (XP)
Control Panel>Printers and faxes>
Then select "Add printer" and choose the first option (Local printer attached to this computer)
An errormessage will appear saying they were unable to find printer. Click next to find the printer manually...
Now select "Create a new port" and choose standard TCP/IP... Ignore the list of different types of printers, now select "From Disk" and then click next... Once The computer recognizes the printer, it all should be in order...
Hope this could help you...!
Apr 25, 2009 | HP Photosmart C4580 All-in-One InkJet...
PC not reading printer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 29, 2009 | Lexmark X2350 All-In-One InkJet Printer
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Printing from PC
use parrallel cable. if there is ethernet port u can use a cross lan cable also.
Sep 02, 2007 | Ricoh Aficio 250 Copier
Ricoh Aficio 450 Copier Logo
151 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
