Question about Philips SA157 512 MB MP3 Player
Need new plug-in
When i turned on my mp3 player a while ago, it simply said i had no files. So, i went to replace them, and the computer told me to download a plug-in, but when i went to the link it wasnt there. Help!
I need new plug in
Posted on Sep 29, 2008
  • 8,596 Answers
Reinstall the Philips Plug-in from the installation CD
Posted on Feb 19, 2008
SOURCE:
Player turns on and immediately goes to a blank screen!
i had the exact same problem and that means that its just getting old and u probably need a new one
Jul 09, 2009 | SanDisk Sansa e270 MP3 Player
I HAVE DOWNLOAD MUSIC TO MP3 BUT I CANT GET ON
If you mean you can't put the MP3 files you downloaded onto the player, then you simply need to plug the player into a USB port on your computer -- either directly into the port (for some player models) or via an extension cable.
Once you've done so, the computer will "recognize" the player as a new disk drive, and assign a drive letter to it. Your computer will normally inform you via a pop-up, that it found new hardware.
Now just use Windows Explorer to drag and drop the mp3 files onto the new drive. This loads the files onto the player. Once the transfer is complete you can unplug the player, and it's ready to go.
Jun 28, 2009 | Kaser Corporation Mambo BW MP3 Player
Missil 1gb mp3
When the song is playing, hit the menu button. That should bring up the 'repeat' menu, and you can pick random from in there.
Jun 16, 2009 | Audio Players & Recorders
Colby 4 gigabyte player won't work... the computer does not detect the driver i plugged it in and said installation problem and then it disappeared on me there was a missing inf file and i don't know what...
First Remove The Device From Your Computer.
Then Install The Disc And Run The Setup Now Restart Your Computer And Plug In The Device Once You've Booted To Your Desktop.
Jan 06, 2009 | Coby MP-C7085 MP3 Player
MP3 player does not turn on
It looks like you need new battery.
May 26, 2008 | Thomson Lyra PDP2842U MP3 Player
Bad Song caused screen to go blank!
move the button HOLD switch ON,to see orange.Hold down REC button and with the REc button holding down,connect the player to the computer.this is Recovery Mode.If your computer recougnize your plaer like 16mbFormat,everything is ok,in this case do as i say in the following text.(if it doesn't been recougnized by the computer...i can't help you)Go to START-PROGRAMS-ACCESORIES-NOTEPAD.IN the new text notepad,do not write anything,go to file-save as.In the box "Save as type" select "all files" and in the box "file name" write :sansa.fmt
Save the notepad file on desktop and copy it in your "16mbFormat"sansa player in recovery mode.16mbFormat is the name of your player in recovery mode wich you will find in My computer.Do not copy anything at there.like music or other files.after that disconect your player and enjoy.this is FORMAT in Recovery MOde.
Feb 14, 2008 | SanDisk Sansa e250 MP3 Player
"MTP DB Mismatch Format?"
The Insignia NS-DA2G needs to be placed in File & Folder mode, and you'll need to have your mac show you all files on the device. Macs will create a smaller file that starts with "._" that contain very little information, but can cause problems with Windows based or Windows preferred devices. These files are not ignored by the PC or certain Windows optomized devices. You should erase these files for the unit to perform normally.
If you are unable to delete these files, you can re-format the device to FAT-32 and that will erase all information on the device. You shouls also hit the reset button (located next to the "HOLD" switch) for about 5-10 seconds to clear the internal settings.
Jan 10, 2008 | Insignia NS-DA2G MP3 Player
My Sansa doesn't keep the new files I put on it
It sounds like there's a problem with writing to the flash card, in which case you'd have to replace the card inside the player.
Jan 05, 2008 | SanDisk Sansa E280 MP3 Player
Pearl mp3 player malfunction.
I have a brand new (2008-2009) hp computer and can not figure out how to download music on it from a cd
Dec 16, 2007 | RCA Lyra RD2765 MP3 Player
Insignia 4MB MP3/video player
File allocation table on your player is corrupt. try to use the following method to transfer files from your player to your c drive... else... all is gone...
You can use Windows Explorer to transfer files to and from your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your files to/from your c drive to the new drive for your player. You'll notice that when you use Windows explorer to delete the files on your new drive for your player that it doesnt remove them from your Music Library on your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Mar 13, 2007 | Insignia IN-MP3256 MP3 Player
Philips SA157 512 MB MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
