Question about Canon PIXMA MP470 All-in-One Printer
How to reset ink level warning when refilling?
I bought a ink refilling kit and refilled the both cartridges- PG40, CL41. The problem is ink level messages show "ink levels low". How do I reset the cartridges to properly display the ink levels?
  • 24 Answers
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Posted on Jul 25, 2009
    Problem Solver:
  • 15 Answers
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Posted on Jul 13, 2009
  • Alebachew Walle Aug 18, 2013
    It is really easy and so effective!!!!!!
    Thank u!!!!!!!!!!!!!!!!!!!!
Waht kind of cartridge is used for canon printer K10282
Your machine is a Pixma MP160. It can use either the PG40 or PG50 Black cartridges, and the CL41 or CL51 Colour cartridges. These can be refilled, but the cartridges have a memory function that will need you to bypass the printers cartridge level calculator. Your cartridge refiller should be able to provide you with instructions for this.
Jan 30, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma 510 black cartridge
I doubt it very much! Your model seems to use the PG40 & CL41. You can also use PG50 & CL51.
See also my tip on refilling these cartridges.
Feb 01, 2010 | Office Equipment & Supplies
Ink refills don't work
See my tip on PG40 CL41 refilling.
Jan 19, 2010 | Canon PIXMA MP460 All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Need help with my printer canon MP190
I refilled my MP190 Black cartridge PG-37 by drilling a hole in the top (roughly in the middle) and using the syringe supplied with the ink refill kit. To make the printer work again, press and hold down the Stop/Reset button (on bottom right hand side of printer) for at least 5 seconds until the display reads 1 again. This bypasses the ink level detector and is explained in the trouble shooting section of the on screen manual supplied on the printer installation CD. It works. It then happened again with the colour cartridge, so I repeated the process. It worked again. This should also work for the PG40 and CL41 cartridges.
Apr 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Error message U051 on canon MP460
Check the Label on the cartridge if it covers a certain area then you will get an error message. Compare it with a good cartridge the label should nearly touch the lugs at top end. Only applies to refilled Carts.
Oct 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon mx310
Canon cartridges have an intelligent chipset to prevent them from being refilled. To have them working properly you need to reset the chipset.
Try the software on this link.
If the above did not work you will need to use a cartridge chip resetter if you want to refill your cartridge.
Jun 06, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP470 All-in-One Printer Logo
5,171 people viewed this question
old marine
old marine
