Question about HP PSC 1510 All-In-One InkJet Printer
Printer output shifts
I'm trying to print business cards and some times the print out shifts verticaly about 1 cm down the page. I have tried every single setup, but I have not being able to solve the problem.
  • 565 Answers
Try Manual Feeding
Posted on Dec 26, 2008
Kyocera FS-1020D starts print 1/2 way down page
Internal tests like Report Prints are printed correctly? Make sure the Paper Size Format is setted correctly both on PC and Printer. Try not to use a Generic or Universal Printer Driver. Try installing printer with an Windows Vista driver if the Win7 and 8 drivers won't solve the problem.
Jan 22, 2015 | Kyocera Office Equipment & Supplies
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
Poor print quality on hp 1312
Hello Terry there are few things i would check :
1) Try printing a demo page directly from the printer, go to Setup>Reports>Demo Page
If you see the poor quality on this internal page that means that the issue could be related to hardware failure. Laser scanner assembly most of the times
2) Check on the toner level for the cartridges by printing a supply status report
3) If the problem is not on the demo page i would try replacing the printer driver for a Post Script Driver, you can download them from www.hp.com
4) You can Adjust the Print Quality by going to Printer Preferences under the driver
Jun 24, 2010 | HP Laserjet CM 1312NFI Color Printer
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Epson Stylus cx5 series
Is media transparent? Epson paper sensor think that no paper. Put white stiker at top left and right of media (about 1 cm height and 2 cm width). It's for tricky sensor.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Ricoh SP c410DN - print dots verticaly down the page - I have clean the roller as instructed.
    Notice what color the dots are. Most of the time you need to replace that color photoconductor.
    Oct 29, 2008 | Ricoh Aficio SP C410DN Laser Printer
    Problem printing business cards
    I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
    Jul 19, 2008 | HP Deskjet 3845 InkJet Printer
    HP PSC 1510 All-In-One InkJet Printer Logo
    41 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
