Question about Acer Aspire 3000 Notebook
HELP My laptop screen has lines in it. When I apply pressure to the top of the monitor it clears but still not working properly. It is an Acer Aspire.
  • Lisa Pilgrim Mar 22, 2007
    I need to know how to replace the LCD. It is on its way. Thanks Lisa
I have an Acer Aspire 5520 laptop, 2 months old. Laptop was opened and a 1 in. rubber bouncy ball was thrown against a wall and bounce back and hit the screen. Appears the LCD is cracked. Had lines going through the screen and a definite mark of colors where the ball hit. I have found a new screen on ebay. Question: Is it easy enough for me to change it out? and how?
Posted on Mar 05, 2008
This is not a solution however I have the exact same issue. did you manage to get it fixed and what did it take to fix it?
Posted on Apr 22, 2007
  • 385 Answers
The first two solutions I agree with. However, I mostly believe that the cable connection from the motherboard to the circuit board for the screen is loose or may need to be cleaned or replaced. It's a very delicate procedure removing the screen to fix this problem so its best you take it to a repair shop.
Posted on Mar 19, 2007
    Novelist:
  • 198 Answers
Sandrew is right. It should be a good thing to go to a service center to have your laptop examined. Inside the display area there is a small circuit board that is the display's controller. This is connected to the mainboard by a set of wires. Probably the connector to the display's controller got out of place and needs to be reconnected properly. This isn't an expensive repair and it's better to let the service centers have a look. It's the safest way. However if you need instructions on dissasembling your display I will provide them if you ask. Good luck.
Posted on Mar 18, 2007
    President:
  • 2,961 Answers
There is not much you can really do to rectify a screen problem, but there are four little black blanks in the corners of the screen,remove and see if any tightening or loosening of the screws alter it. Caution applies as the wireless receiver is built in the screen and can get damaged and that may also be causing the interference.
I have Acer Aspire 5580. I am facing problem with the graphic, it is showing lines and color patches. When i am extending the monitor to external display, the external monitor is showing nice graphics. I...
if you changed the screens to a working one, then you should have a clear image on the main screen, or its damaged, or one of the monitor ribbons is not seated properly. have you updated your graphics driver?
Sep 19, 2017 | Acer Aspire 5580 Notebook
My acer lcd monitor of 18.5 inch is going through a problem in which a large number of black rays are appearing and flowing up and down in the screen.... so the lcd displays very badly so wat to do my...
It depends, if the lines are due to physical damage then the warranty is no good if the screen is faulty the your fine. the way to find out is if you apply a little bit of pressure to the line and it gets bigger then its physical, if not get your warranty out
Dec 06, 2010 | Acer Aspire DualCore2GB/160GB PC 18.5"LCD...
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
My laptop, an Acer Aspire 5715z, has a big ol' white patch on it with a smaller one at the top of the white one. It covers about half of the screen, and it has blue around the start of the white line.
Oh okay. Your screen is physically cracked. Its broken, its going to need to be replaced. Thats why a part of the screen is coming and then you see splotches on the screen. Looks like somebody hit directly with something or stepped on it. If you turn the laptop off and shine a light on it, you might be able to see where the crack originated.
In the meantime until you get another lcd screen, you can hook up an external monitor to the laptop and use it like that for now.
May 23, 2009 | Acer Aspire 3610 Notebook
My Aspire 3680 laptop screen cannot appear properly
Try removing the plastic above the keyboard and wobbling the cable going to the monitor. Is the backlight appearing to work at all?
Apr 23, 2009 | Acer Aspire 3680 Laptop
My screen of my laptop acer aspire 5670 is smaller
3 possible solutions
1. There is a monitor mode to display correctly when connected to a larger monitor, look at the top line of keys on your keyboard for a key with 2 monitors on it. You usually need to press the FN (Function key, bottom left) hold it down then press the monitor at the top
2. Your display drivers are incorrect see http://www.howtofixanything.co.uk/howto-52.html to update your video driver
3. Try starting Internet Explorer and click Tools (At the top) --> Windows Update
See if any updated Video Drivers are available
If you cannot see tools at the top in the menu bar pres the <alt> key once
Jan 13, 2009 | Acer Aspire 5670 Notebook
Both screens wont work
No mention of how much ram installed ???
Are you using ACER GRIDVISTA
This program handles the multi screen out put
or
Standard Screen Properties,,,,,,,
Try this
DESKTOP>Right click properties
DISPLAY PROPERTIES>Settings
With both screens connected.
There should be two windows displayed ,
a highlighted white one and a grey one
Click IDENTIFY.
ONE SCREEN-
Should display a number 1 on the screen it has attached.
TWO SCREEN
Should display a number 2 on the external screen.
Once you get IDENTIFY to work then set resolution sizes of both individual screen.Apply and ok to save settings
If using GRIDVISTA then set the setting for the output functions and save theme as a theme BOTH or LAPTOP AND EXTERNAL MONITOR and its accessible from the desktop right click.
Good luck I have a couple of these I use for my Media Centre wirelessly networked thru the house.Great machines.
Jan 11, 2009 | Acer Aspire 3680 Laptop
Aspire 5600 gets horizontal lines on lcd
The horizontal line means that there is a loss connection in the horizontal projection of the monitor. This can be resolved by fixing the horizontal panel board that gives error. this require quite expert in the LCD troubleshooting. However, if you believe that you can do it, ok you may proceed.
please donot rate me if this not solve the problem. because i need more higher rating. just notify if you need more solution am here to assist. melnavz
Apr 09, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3000 Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
