Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Gateway FPD1730 17" LCD monitor has no power
I have 5 of these that do not give a green LED when plugged in. However, I am getting voltage output from the power board. Since this is obviously a common problem with these units, does anyone have any experience as to what the problem is? I have found some info but it relates to models with separate inverter & power boards (these have combo).
No caps are visibly blown.
-Should I change them all anyway?
-What's a good method for testing a cap with my DMM?
Fuses test OK with beep test mode on DMM.
-Should I test using the Ohm function?
No shorted IC's.
-What's another good method for trouble shooting component failure without schematics, service manual, or expensive test equipment?
I know I should use schematics, but I'm self taught and it's still a bit complicated for me. They're also hard to find. And I don't have an O-scope yet.
Please only reply with helpful suggestions. ie rather than saying
"Well your screwed without the proper test equipment."
try
"Well your screwed without the proper test equipment. I recommend getting a Zx1500 O-Scope by Acme Co. It has the capabilties you'll need for TSing LCD monitors, and it won't break the bank."
  • Elisha Tigah Jan 15, 2009
    Same problem. Troubleshooting the inverter board but so far no luck. I measured the voltages on most of the components on the bad inverter and it was the same as a known good one. Tried replacing the 47uF cap on the inverter but still no luck. Please help!
  • clofthouse Jan 16, 2009
    we are working on this same issue too and nothing has worked. Resoldered everything on board.
  • 624 Answers
SOURCE: Replacing Inverter Board
I did some poking around and only found a few places that sold inverter boards for this monitor. Ebay has one that sells for about $80: http://cgi.ebay.com/Backlight-Inverter-for-Gateway-FPD1930-LCD-Monitor_W0QQitemZ160070918225QQcategoryZ174QQrdZ1QQssPageNameZWINQ3aPOST0Q3aRECOQ3aBINQQcmdZViewItem I wasn't able to find any specific instructions posted, however, taking a typical LCD panel apart and replacing the board shouldn't be too difficult. The only hard part is not getting shocked, which is why this is not a job for the typical user. Anyway to disassemble the typical LCD you remove the pedestal from the back of the LCD then remove the screws around the back of the LCD, remove the back and look for the inverter board. Typically it is covered with a metal shield; again the hard part is knowing how to correctly handle the parts. Considering you can buy a new 17" LCD for $120 to $150 (and has a 1 year warranty) you might want to consider investing in a new monitor instead. If you have any other questions let us know, otherwise please don?t forget to rate this posting.
Posted on Feb 06, 2007
SOURCE: Xerox 17 XL765 LCD monitor Wavy lines but pitcure is good
good luck ive had this problem with my samsung 2232bw for 2 months, replaceded the monitor and every hardware piece in my machine an dstill the same problem
ive had help from microsoft, and all manufacturers of my hardware, no solution
give up i have
Posted on Jul 08, 2008
SOURCE: 19" Proview 900p lcd monitor backlight
The 7812 device is a voltage regulator. Either the reg has failed or the input to the reg is no longer approx 12volts. It should be more than 12volts so that the reg can control the o/p .
Posted on Sep 05, 2008
SOURCE: IC Power 19'' LCD-Will not Power Up- No Lites.
This is a follow up to my last submission about my discovery of bad caps on the FPD1960 LCD flat screen Gateway 19" computer monitor. To recap: After two and a half years of excellent graphics quality, my monitor suddenly went blackout. After pushing the power-on button, the screen would come on for 1-second, then go black. Repeat, again and again, same result; comes on for 1 second then blackout. THE REPAIR: After carefully but forcefully prying open the case, I unscrewed and unplugged then removed the screen and set it aside, then unscrewed and removed the power supply board. Sure as shootin, bulging (and slightly leaking) capacitors were immdiately apparant on this board. That other fella's submission was right on target. Search Wikipedia for "bulging capacitors" to get the inside scoop on this widespread problem. Major manufacturers are well aware of this issue, but fortunately for them it occurs some 2-years out'a the box, and after the warranty expires. This is one time I wish I'd bought the extended warranty! Anyway, I finally got my 5 caps from Ebay in the mail today. Specifically, they are 470uF 25volt 105-degree (use only 105's because some are right near a power transister heat sink---so I'll bet they get mighty friggin hot. After carefully replacing the old caps with the new (you'll need a solder ****** along with your solder iron), I reassembled, powered-up, and began to thoroughly enjoy the fruits of my labor. It's working like new once again. THE CAPS ON THE POWER SUPPLY BOARD ARE DEFECTIVE.
Posted on Dec 08, 2008
ITTech7574
  • 85 Answers
SOURCE: Gateway monitor (FDP1965) Power/video problem
You have a problem with your lcd..get it fixed by technicians...
Posted on Aug 28, 2009
Power Supply Issue - Green LED ON..no power up
tried to disconnected the 24v supply connectors going to the power inverter board which may the cause of voltage drop. after you disconnect then if still no output 24v dc coming from the power supply board the cause will be bad power supply board. check for an open resistance or bad regulators going to the 24vdc out. by the way you should connect all the connectors going to the main board to turn on the processor and the inv_on voltage going to the inverter board.
Nov 01, 2012 | Toshiba 65HT2U 65" Class Full HD LCD HDTV
Sir I have Viewsoni VA1716W model LCD monitor But power LED not on I measure SMPS output voltage 12V and 5 Volt are available but power led not glow what to do please give me some tips.
Since the power supply is OK, the next place to check will be the logic board, you need to find out if it is getting the 5vdc feeding it and also check for 3.3v, 1.8vdc, etc voltage regulators on the logic board. So far I cannot find free service manual to download for it.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 22, 2011 | ViewSonic 17"...
IBM L190 LCD - the LED beside the power button corner cycles green for 1 second, off for 1 second as soon as it is plugged in. The unit won't power up, the LED just cycles green/off whenever it is plugged...
It's clear the problem is the display, but you can still try these 1. unplug and replug while the both is on 2. turn on, off couple of times 3. keep the LCD on for about one hour these are anyway temporary fixes :(
Jan 30, 2011 | IBM ThinkVision L190 19" LCD Monitor
When system restarts, monitor blank for hours even when the power LED displays green
If you can see a dim image on the monitor then there is a back-light problem.
The fault could be an inverter problem which supplies high voltage to the CCFL lamp or the CCFL lamp maybe faulty. The CCFL lamp is a mini fluro tube.
Check out LCD parts for service, parts and DIY info - click on this link :-
www.lcdparts.net
Oct 25, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Viewsoniv VA 902 LCD 19" monitor
If the signal cable is detachable from the monitor, you could try with another cable... Regarding the power, I' not an expert, but if you're familiar with electronics basics, like risks of high voltage, soldering, etc, and you'd like to experiment with the unit, then I can give you some hints.
Mar 19, 2009 | ViewSonic VX900 19" LCD Monitor
Dell 20" monitor doesn't power up
I suspect Best Buy will most likely replace the monitor's entire power circuit. It's possible that you shorted out a fuse, the input transformer, or some other component in the monitor's power supply. The only way to tell for sure is to disassemble the monitor and check the circuitry visually and with a meter. This job is best left to a qualified technician.
Jun 13, 2008 | Gateway FPD2275W LCD Monitor
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
Aug 15, 2007 | Neovo AG 17" LCD Monitor
Intermittent power on problem, monitor now completely dead
See other post regarding IC901 Please feel free to RATE me if it helps
Aug 27, 2006 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
267 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
