Question about 2wire 2700HG-B Router (2700HGB)
Printer HP Officejet J4680 All -in-one
I was happly enjoying the computer and printer, when a gitch occured, and a sheet failed to file into the printer. As faith would have it a blinking light on the right side side of the printer started blinking like crazy.
I taught surely it is an old fashon paper jam. I looked all over no paper jam. I gave the computer a command to print a page. The computer printed one page.
Thereafter, regradless of how much I tried the light keeep blanking, and the printer will not accept any command. ( I am using on line service)
  • pitreca Dec 22, 2008
    I had an ink problem.
    President:
  • 2,110 Answers
Once you have checked that i would try plugging it power and usb wait a minute and plug it all back in except i would plug the usb into another port. If this still does not work for you, i would uninstall all the software including drivers reboot and try again.
Posted on Dec 15, 2008
    Sergeant:
  • 306 Answers
C tis>> click here
  • 2wire Master
  • 6,487 Answers
Try first to turn off the printer for 5 minutes and open it up then check for any foreign object inside it that is causing this problem, and you can also remove all the cartridges and let the printer turn off for about 30 minutes...
  • 734 Answers
Please tell me is there any error message on display.
Thanks
  • futureloginn
    futureloginn Dec 15, 2008
    re install software that came with it.
    Sounds like it took a powerspike.
    try the software reinstall first.
    goodluck
My OfficeJet J4680 Stopped Printing Wirelessly. I have an Acer Aspire One netbook running XP 2002 Service Pk 3. I have an OfficeJet J4680 which is hardwired to my main computer, a Mac mini and connected...
I've seen this happen on several HP printers. You have to "point" the computer back to the right IP address. Go into the printer properties, under the Ports tab, and highlight the correct port for that printer. Then click on the Configure Port button below the list of ports. Next to "Printer Name or IP Address," type in the correct address -- 192.168.1.110. Then click OK to exit that window and OK to exit the Properties window and save the change, and after a couple of seconds for the IP address change to take effect, you should be able to resume normal printing.
Jul 11, 2011 | HP J4680 Office Jet All-In-One Printer
How to scan with HP officejet J4680 printer
To scan from the device control panel (direct connect)
1. Load the original.
2. Press the left arrow or the right arrow to select the Scan function, and then
press OK.
3. Press the right arrow to select what to do with the scan, and then press OK.
4. Press Start.
Mar 15, 2011 | HP Officejet J4680 InkJet Printer
How to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
How to install driver for hp officejet j4680 all in one printer
Have you got an installation CD or downloaded the printer driver?
If not you need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model printer and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
www.hp.com/#Support
Then click on the downloaded file to install the printer driver.
Nov 29, 2009 | HP J4680 Office Jet All-In-One Printer
Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Nov 28, 2009 | HP Officejet J4680 InkJet Printer
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
Officejet J4680 won't printer after router reset
) You might not have to do this step, but if all else fails reset the HP Officejet J4680 network by pressing the setup button (the wrench) go to Wireless Menu and Press OK then go to Reset Wireless select YES and press OK. If that doesn't work then there is another reset that I found in the setup menu (the wrench) under Tools and then Restore Defaults. I wound up doing both resets on my Officejet J4680
2) Power the HP Officejet off and on for good luck (again optional but might help).
3) Make sure the the wireless on the printer is enabled by pushing the button on the left side front under the 802.11g so that the blue wireless light turns on. (again optional, but make sure the blue antennae light is on)
4) Connect to the HP Officejet J4680 wireless printer directly from the MAC (this is pretty cool stuff) Click on the Airport icon at the top bar of your mac screen, if you see the hpsetup listed then click on it, if it is not listed then click on join other network and type in hpsetup and click Join. This will join the mac to the Ad Hoc HPSetup network and you can now setup the printer from the mac!
5) Important: Print a network settings report on the HP Officejet by pressing the setup button again (the wrench) go to Print Report and press OK, go to Network config and press OK. If you try and print this before you connect (step 4) you will not get the info you need in the report, so connect first from Mac to HP then print this report.
6) fire up safari or Firefox or chrome browser on the Mac and type in the URL that is listed on the report you just printed out. It starts with http:// type in the http:// and the 4 numbers all together with no spaces into the address bar in your browser and press return.
7) you are now connected to the HP Officejet J4680 via the web browser interface. Click on Networking, then Advanced, click the infrastructure tab and fill in the passphrase info for your router type it again to confirm, then click apply. It should now connect and print from the router. But below is a good video with even more detailed info:
8) More Officejet J4680 setup via the mac using this very thorough guide: http://www.youtube.com/watch?v=Rjd1ZqJ89N4
Jul 15, 2009 | HP J4680 Office Jet All-In-One Printer
Trying to install HP J4680 AIO printer and installation fails at
jim it is ur printer driver problem because ur software is damage u need to download the driver from net. or purchase a new driver.
Mar 24, 2009 | HP J4680 Office Jet All-In-One Printer
2wire 2700HG-B Router (2700HGB) Logo
54 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
