Question about Adobe Photoshop 7.0 for PC
Unable to uninstall Photoshop 7 on Vista
I have installed Photoshop 7 on Vista. I am unable to uninstall it. There's no uinstallation file in start menu. When I try to remove it using add/remove programs, it aborts saying uninst.isu is not valid or coeeupted. What should I do? Reinstalling it and uninstalling doesn't seem to work.
  • sridutt629 Dec 15, 2008
    It still shows in add/remove programs
  • 827 Answers
Try deleting all the files from the Photoshop folder in the Adobe folder in Program Files.
Then download a free program called ncleaner. just type ncleaner into google. after you install it, run it and press the Clean System button, then Clean Now. Just click yes when it asks you. Then click back to the main screen, and click find junk. that should get rid of any leftover files from the photoshop install.
chris
Posted on Dec 15, 2008
  • chris grams
    chris grams Dec 15, 2008
    You should have rated that as Fixed. The program has been deleted. It will still show in the add/remove program list because you didn't uninstall it from there.
    if you want to remove it from the list, (although it doesn't make any difference, the program has been deleted) then download TweakVI and edit the list. here's a link for you.
    http://www.download.com/TweakVI-Basic/30...
    chris (ziraffa)
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Jul 02, 2011 | Adobe Photoshop 7.0 for PC
How do i install adobe photoshop 7 ?
Put the disc in the pc, it should autostart the installer.
If it is not compatable with your OS, try right click on the main .exe file / installer file and try to install under compatability (vista or win 7)
Oct 15, 2010 | Adobe Photoshop 7.0 for PC
Since upgrading to Vista and now windows 7 I cant
Start the "Program Compatibility Wizard".
Tell Vista that you want to install an 'XP' application.
Point the Wizard to the CD-ROM containing the software, and it will install.
Jan 15, 2010 | Adobe Photoshop Elements 2.0
Installed photoshop 7 on my laptop and everytime I start the program and click on editor, it tells me the program will automatically shut down. Is there a fix for this problem?
The error telling you that Photoshop 'will automatically shut down' is a waterd-down way of telling you there was a critical error and that it was not able to open. There appears to be a corruption in your Photoshop installation.
I would recomend uninstalling Photoshop 7 and then re-installing it again as follows:
- Click Start > Control Panel > Add/Remove Programs (or 'Programs' in Vista or Win7)
- Locate Adobe Photoshop 7 and click on it and select Uninstall.
- When it has completed, restart your PC.
- Once restarted, re-install Photoshop 7 via the CD/DVD.
Hope this helps,
-Tor
Nov 21, 2009 | HP Computers & Internet
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Can't install photoshop elements 7 on my vaio (vista)
If you had a prior version of Elements on your computer, make sure you have uninstalled it via Add/Remove Programs. This process doesn't remove everything, however. You also have to remove the database cache file manually. To do this, navigate to c:\Program files\Common files\Adobe\Adobe pcd\cache\ and delete the file named "cache.db" by dragging it to the recycle bin. After I did this, my install went fine.
Feb 25, 2009 | Adobe Photoshop 7.0 for PC
Is CN66588 132 Q8150A the model number you requested?
Thanks for giving me the information. we need to first uninstall all the previous traces of the drivers to do the same . Download the HP uinstaller from the following link: The file name is
hpvistascr.exe
website: http://tinyurl.com/63q75d
1. Make sure the printer is disconnected.
2. Save the file on the desktop
3. Run the uninstaller.
4. Restart the computer when finished.
Download and install the Vista drivers from the link below
http://tinyurl.com/2l75pj
Instruction on how to install the same are given on the website.
Thanks
Proton
Jun 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer
please uinstall and re-install the entire s/w.... note : plug in the usb only when prompted.uinstall the s/w after unplugging the usb. uninstallation----- go to add & remove program....remove all the printer related s/w in the list. c:/ - program files - util - ccc - HP/Hewlewtt Packard - Digital imaging(could be in hp or in hewlett packard)-uinstall/remove NOTE: if u r not an hp computer user delete the entire HP/Hewlett Packard file.Do not do so if the computer you are using is of hp. open start - run - type regedit - enter-registry editor opens - HKEY_LOCAL_MACHINE-software-if u r not an hp computer user delete the entire HP/Hewlett Packard file.Do not do so if the computer you are using is of hp/Digital imaging(could be in hp or in hewlett packard)-uinstall/remove restart the computer give a print command
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Adobe Photoshop 7.0 for PC Logo
736 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
