Question about Acer Aspire 5500 5570-2609 Laptop
Problem with the logic board marked as 0171-2242-0153 and
I have Viewsonic VG150,
3150-0122-0150 by means of silk screen on green PCB, looks original by
the fab house. Also E11131070 is printed on a white sticky label,
affixed at a later time.
The issue is that my VGA image is fuzzy, with white horizontal lines
from top to bottom. You can still see the payload image behind the
white horizontal lines. The lines seem pretty stable with just slight
flicker.
Using deductive logic, I condicted more tests and observed that the
built-in menus (generated internally) for contrast, monitor info, etc
are perfect. No lines at all. The lines show up only when VGA signal
is present.
So I deduced the issue is on the analog part, close to the signal
connector - bad pre-amp, bad gate, etc.
Not having schematic I figured the first hit is the Mitsubishi
M52743BSP chip. Ok swapped it out (yay $5 at Newark) but my lines are
still there and my built-in menus are clear and stable.
I see few AmTran ICs, some a good suspect but I though I should
increase my IQ approach in troubleshooting this issue.
Any help?
Thanks
~Boyan
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
ViewSonic LCD monitor displays "No Signal Digital" message
There is something wrong with the main logic board. The firmware thinks that there is a DVI connector installed. Such problems with other devices are fixed by reflashing the firmware. But I don't see any connector on the board for that purpose.The faulty flash memory chip is marked with "A", meaning there is flashed the "A" firmwre version of all possible versions - probably this with only VGA connector. My suggestions are: try to find similar working logic board. I didn't find any on ebay, but you may find somewhere else. The other option is hard one - to try installing DVI connector on this board. Unfortunatelly we don't know the parameters of the parts needed. There have to be several diods, some capacitors and a transistor, all SMD. There is also a missing 8-legged IC probably connected somehow with the DVI. :(
Just for case carefully inspect the cpu legs for bad solder.
Apr 07, 2012 | ViewSonic Graphic VG2021m LCD Monitor
Power light is green but its screen is grey
The sreen gives out grey glowing screen only means that the T-CON board is not getting the 5 or 12vdc feeding it from the logic board, or blown fuse due to short circuits in the T-CON board, you need to troubleshoot it.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 29, 2010 | ViewSonic VG930m LCD Monitor
Power is on but the screen will not turn on
IF the backlights are on but you just get dim glowing on the screen when look at the screen in darkened room then the T-CON board is bad or it is not getting the 12vdc from the main logic board. Need to use logical troubleshooting before buying the wrong parts.
Hope this works.....
Jul 02, 2010 | ViewSonic N3251w 32 in. LCD HDTV
Viewsonic vx2235wm has a white screen. What is the problem?
If you have white glow on thescreen with no pictures, the problem can be the LCD panel controller board (part of the LCD screen) is not getting the 5v from the logic board. See pictures of failed VX2235W for guide as to what to look for first, otherwise you will need new LCD panel.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Mar 29, 2010 | ViewSonic VX2235WM Monitor
Hi there, My Viewsonic failed about a year ago and I'm hoping to bring it back to life Problem: It won't turn on. Observations (thus far): Green light visible on AC Adapter, as well as on Logic Board Caps...
Buy a new monitor!! Seriously, unless you're the techie type that likes to tear open electronic equipment to see how it works and/or fix it, you're better off buying a new monitor especially if this old monitor of your's is a LCD.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Mar 11, 2010 | ViewSonic VA550 15" Flat Panel LCD Monitor
Error on Canon Pixma IP5200
20 times Other hardware error [6500] - Logic board ***'y (QM2-2670)*1
Its the small circuit board next to the carriage unit
You can get one for about $30 from this company web site.
www.euro-parts.it/download/slowmover_oct-2008.xls
You probably have to contact them directly to get your exact circuit board.
Sep 29, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Need help with Viewsonic VX924
10 pin top to bottom connecting at right hand side; colours = bla,bro,red, X X ora,yel,gre,blu,purple
8 pin left to right connecting at top ; purple, blu, gre,yel,ora,red,bro,bla
Mar 14, 2009 | ViewSonic VX924 19" LCD Monitor
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Acer Aspire 5500 5570-2609 Laptop Logo
272 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
