Question about Kitchen Ranges
Galaxy Gas Stove; the oven pilot light will not stay lit.
The oven pilot light will not stay lit on the gas oven on stove. When it is lit it will not stay lit. Then after will smell gas.
  • jzerrien Jan 11, 2009
    Same problem, apt. size gas stove, recently the burner and oven pilots not staying lit. Had the gas heater serviced a few months ago and am wondering if it redistributed gas flow? Doesn't seem likely....
4 Suggested Answers
SOURCE: O'Keefe & Merritt Contempo Gas Stove Oven won't light
Probably needs the ignitor replaced. http://www.handymanwire.com/ubbthreads/showflat.php/Cat/0/Number/408747/an/0/page/332
Posted on Jan 07, 2011
  • 548 Answers
SOURCE: OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Posted on Feb 14, 2009
  • 3 Answers
SOURCE: I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Posted on Oct 16, 2009
Pilot lights will not stay lit on stove top or oven. Can light burners with match. Crosley c3100paw
You need to clean thermocoupling off it what the pilot lit uses to stay lit. you canuse sand paper or brush May need to replace, clean gas tubes on pilot also could be that
Dec 12, 2011 | Crosley Kitchen Ranges
The oven pilot to our gas stove was out, while the stove top pilots were still burning. When trying to light the oven pilot, it would light but not stay lit. Model #CG31200BDW
have you done testing and checking the unit, it seems that your problem was on the thermal fuse, and this part need to be replaced if you find it burned or busted
Aug 07, 2008 | Maytag Kitchen Ranges
Was preheating oven, while cooking on stove stop. heard a puff sound open up oven thought it was on but it never heated up. the electric light comes on but does not ignite. the broiler does the same. ...
Gas ovens are fitted with at least one safety device and it could be it has failed.
The safety device is bypassed while the pilot light is lit. The pilot light heats a thermocouple bulb which switches the gas on to the burner. As long as the pilot light continues to heat the bulb gas will continue to flow - until the thermocouple fails, they aren't long-lasting...
Feb 03, 2018 | Hotpoint 30" Self-Cleaning Freestanding...
Aug 27, 2009 | Garland H286 Gas Kitchen Range
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Kitchen Ranges Logo
473 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
