Question about Sony PlayStation 2 (PS2) Console
PS2 won't read Original/Backup CD/DVD
Playstation 2 Fatboy
Version:SCPH-5001 Version 9/10
Modchip Installed:Matrix Infinity (Pretty Sure it is not a clone)
Modchip Installation:I did not install it I sent it out to some Luigi similar like avatar name, guy from out of state.
Hard Drive: Maxtor 200GB
Software Used: Independent Exploit 3.4 w/HD Loader loaded from a CD
Issue: I travel by car alot from Orlando to South FL. And I carry my PS2 with me using a specialty bag I got from Gamestop. After one of my trips I noticed that the PS2 was not able to play my Backup PSX/PS2 Games and not able to run the Exploit CD. However it was able to play Original PSX/PS2 games.I thought maybe one of the wires inside might have came undone. So I went ahead and opened up the PS2 and tried to see if I could resolder the wire that probably came undone back to the motherboard. I came across some problems
*I chipped some of the plastic on the Fan Header Plug
*I cleaned the Laser Lens which maybe the reason it wont read anything now
*Was not able to remove one of the precision screws on the Main Shield holding the motherboard down
I tried to put everything back 2gether but the problem got worse. It was able to power on and no noises I could hear but now it won't read anything at all CD/DVD's nothing just sits there acting like its trying to read the disc
Help Please Help Please
Let me know if anyone on here can:
*Diagnose this problem
*Resolder the Modchip if necessary
*Execute a simpler method for me to run my Backups without loading from a Exploit Cd everytime
If so I pay well with Paypal or Money Order
  • 2 more comments
  • Remz Dec 21, 2008
    I read your Forum Guide very informative.
    But it seems like I would have to be swapping disc to be able to play Backups.
    I bought another used Version 10 PS2 wondering if there is anyone out there who still installs modchips on PS2's..?
  • Remz Dec 23, 2008
    Alright I opened my PS2 yesterday. There was a ribbon cable not connected. I connected it back up and used an air cleaner along with swapping the lens with alcohol. I put everything back 2gether and it works. Now how do I get the MC Exploit going again since I can read copied dics..?
  • Remz Dec 25, 2008
    I appreciate the help I was able to open up the PS2 and clean it up with some air cleaner and i cleaned the laser by swapping some alcohol on a Q-tip.I noticed while I was taking it apart one of the ribbon cables was disconnected. After I put everything back 2gether it worked like a charm. And I just installed the FreeMCBoot although I didnt know u needed to patch the games for the ESR to wrk which is no problem just irks me thought I could bring my memory card to any Ps2 and load backups that I had created beforehand
  • ninexunix
    ninexunix May 11, 2010
    Well, I have a method for you to use using what we call a retail trigger disk instead of an exploit cd it binds to a PS1 game. More info can be found on my forums:
    http://www.carpenoctem.ws/modules.php?na...
    Kinda does the same thing your exploit cd does but the files are stored on your memory card instead of the disk itself and it uses a PS1 retail disk. Commonly referred to as a softmod. Since you have a chip it's not like you have to worry about swapping so disregard the cogswap stuff. All you really need is the ability to boot into an elf loader so you can access HDadvance n your other stuff.
    However, since you can't read even retail media need to get that part up and running first. Since you said you cleaned the lense manually I have to ask how far down did you tear apart your PS2 and if you did remove the DVD assembly did you properly reattach the ribbon cable that connects the lens to the motherboard? If you haven't messed with the large white cog wheel within the dvd assembly itself It would lead me to believe that you have a ribbon cable unplugged someplace around the dvdrom assembly. I'ld start there first to make sure all those cables are firmly plugged in. Just cuz the disk spinns doesn't mean the lens is moving. So i'ld start around that area first.
    Hope that's of some help
    9x|
    Scholar:
  • 64 Answers
The Purpose behind the guide to you is emulate your exploit disk, instead of using the disk you use, you're storing the exploit files themselves to your memory card ie. you're ps2 menu and HDloader and any other .elf file. Then you're using the PS1 (retail) game to cause a buffer overflow exploit to load the elf files stored on your memory card, once this is done you get that modified PS2 menu. As I said in the first clairication request the swapping stuff doesn't pertain to you becuase you have a mod chip installed. The main purpose for you to use what i posted eariler was to give you your modified .elf PS2 menu back (cuz all of your tools were stored before on your exploit CD wich is a non retail burned copy) this gives you a way to boot up with things that are native to the PS2 (memory card and retail PS1 game) from the .elf PS2 menu you should be able to see better what is going on becuase you can access each disk type contents from that menu and should be able to launch the game (if your laser lense is functioning enough to read retail PS1 games) from the menu itself. Or if you've been using HDloader plop that .elf onto the memory card (explained on my site) and just navigate to that via the .elf PS2 menu and you'll at least be able to load games stored on your hard drive. This is just something you can use till you get your new PS2 chipped out.
Of coarse this is all speculation. If your PS2 can't even read retail PS1 games none of this will even work.
Sry I don't know anyone that does the chipped stations nemore. I'm sure someone on this site still does though.
Posted on Dec 21, 2008
  • ninexunix
    ninexunix Dec 23, 2008
    Aight, kinda need to know what it is reading and is not reading, by your statement, i'm under the impression that it's reading retail games. If this is the case follow the instructions on my site. All the links for the downloads you need are also there. The only thing you shouldn't have to tinker with is cogswap. You can skip that. Since it's not reading burned media anyway. We can at least get your hard drive up and running again. Get the PS2 Menu elf files (uLaunchELF v3.7.2 located on my site in a link on that page) and get HDLoader v0.8b (also located on that page in a link) Then follow the directions to make the .save file. Here is how the order works:
    Get a retail PS1 game(one that your ps2 will read) (any will do)
    Get a codebreaker like disk (action replay max, codebreaker, gameshark, are all suported by the software we'll be using)
    Get a usb thumb drive (one that action replay max, codebreaker, or gameshark can see the contents of, may require testing to make sure the usb thumb stick works with w/e codebreaker like disk you're using)
    unzip all the files you've downloaded from my site, you should have (if you've followed directions in my tutorial)
    IDGET
    Titleman Frontend
    PS2 Save Builder
    ULaunchELF v3.72
    HDLoader v0.8b
    Next follow the directions on my site(starting with the Digitalex's title ID getter) on how to make the .save file (think of this .save file like a zip, all you're doing is taking the collection of your exploit files, in this case: ulaunchelf, and HDLoader, and making a file that your codebreaker disks will see)
    Next follow the directions on my site on how to take this .save file and put it to your thumb drive.
    Next boot up your ps2 with your codebreaker/action replay max/gameshark and navigate to the section that allows you to access files from usb thumb stick. (every one of the three disks mentioned has a section in it that allows you to access codes and copy them to your memory card.) all we're doing is abuseing this to allow us to copy things over to your memory card, and tricking the codebreaker like disk into thinking we're just copying cheat codes. Instead we're copying over our custom made .zip like file with all our programs that we'll be using.
    From the beginning of my instructions on the site you'll notice what we're doing is binding the exploit to a trigger disk. In this case a PS1 retail game. This is the exact same thing your exploit cd is doing. The only difference between this and your exploit cd is that we're storing all of our programs on the memory card and using a PS1 Game as our trigger. Instead of storing files directly to the CD and using the CD itself as the trigger.
    Once you have everything completed the only thing you need to do in order to boot into it is, have the memory card (with all your files saved to it) in the PS2 and your trigger disk. When everything is done correctly when you start your ps2, your screen will flash white and you'll get this screen:
    or something similar that will give you error messages (dun flip out over the error messages it's common durring the first run of this program.)
    Follow instructions on my site on how to setup your menu so you can access HDloader. Now, since you've already setup your harddrive with all your games on it, there is no need to go over how to setup HDloader. Just set your menu to point to HDloader (instructions on my site) and run it and it will allow you to access your games you have on your hard drive.
    If you get lost or confused just follow the directions from A to Z on my site. There is not a single question i do not cover nor is there any possible way you can get lost or confused if you've read and understand my tutorial on my site. I walk everyone through it step by step from start to completion and equip you with all the software you need (not hardware) in order to do what you need to do. There is not a single thing (above) that is not located and explained and covered in my tutorial on my site.
    If you need any more assistance on this issue let me know. Everything is 100% str8 forward on my site. If at anytime you get lost just follow the directions from the beginning.
Ps2 slim modded doesn't read ps2 modified games
Most likely the console was modded and it was not modded to take modded games
Jun 23, 2014 | Sony PlayStation 2 (PS2) Console
Tip
Playstation2 SCPH 3000 - 5006 General Problems
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
Lens Problems (Optic)
  • Optical Spull not move (up down).
  1. Check the flexible cable.
  2. Check the Optical spull.
  3. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  4. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  5. Check the optical flexible cable socket.
  • Optics spool laterally tilted or irregular jump when the engine turn on.
  1. Check the resistor on 102 block (In IC Servo Master Control area = CXD 3098 : 470-8pin,102-8pin).
  2. Check the resistor under IC Servo Master Control.
  • Optics can only read one CD/DVD format.
  1. Check the Optic Laser Diode.
  2. Check the Optic Laser Diode with Voltmeter : V3 (CD=1080 to 1260, & DVD=800 to 1300), V4 (CD=850 to 900, & DVD=1200 to 1400), V5 (CD=1200, & DVD=1400), V7 (CD=1200, & DVD=1100 to 1400), V9 (CD=1200 to 1400, & DVD=1200 to 1400).
  • Optics Lights not lit (Lens not light).
  2. Check the optics spull.
  3. Check the SP 3727 IC.
  4. Check the Amp transistor ( in IC SP 3727 socket board), Upper for CD & under for DVD.
  5. Check the IC 7805 (IC Regulator).
  • Excellent optics but won't to read.
  1. Check the mecanic gear.
  2. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  3. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  4. Check the ModChip.
  5. Check the IC SP 3727.
  6. Check the resistor (in 220 block), between IC Servo Master Control & IC Interface (CXD 9611 BR).
  7. Check the transistor (in socket optics= pin 6).
on Sep 16, 2010 | Sony PlayStation 2 (PS2) Console
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
What is modding....how to install ext hard drive on the ps2 slim scph 90004
Modding is the process of putting a mod chip in the ps2 to read burned games and to hack games. I wouldn't recomend doing it because it is highly illegal.
Feb 27, 2011 | Sony PlayStation 2 (PS2) Console
My moded playstation 2 scph-90004 can't play 4.7gb dvd movies?
Depending on what modchip you used, sometimes DVD Playback can be lost, you need to ensure that your modchip supports DVD playback but there is a way around this, now that you have a modded system you can run arbitrary code and .elfs, just google "Free MCBoot for ps2 slim", after its setup download the media player for ps2 burnt it on a cd rom or put it on a pendrive and run it, Hope this helps...
Oct 27, 2010 | Sony PlayStation 2 Slimline Console
Playstation 2 is 2 years old. Will not read game discs or DVD's. Any suggestions???
Sep 18, 2010 | Sony PlayStation 2 (PS2) Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
PS2 DVD version
Hi SDK0013,
I am not sure which version PS2 you have but the only way to realy get there is to change the motherboard from one version to another.
I know that SCPH-50001 Motherboard will fit in a  SCPH-39000  case.
Oct 25, 2007 | Sony PlayStation 2 (PS2) Console
Backup won't work!!!!!!!!!!!!!!!!!!!!!!!!!!
You need to use DVD-R.... This is the only solution! use that and you should be set...
May 01, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
2,615 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
