Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
WFMC3200UC Broken Plastic Piece
After running a comforter through, I found it was dripping wet. I ran it through another spin and checked again. This time it was still wet, all ripped up, and there was a broken piece of plastic inside the washer with it. I found where the part broke, but don't know what it does, what it's called, if I need it, or how to order a new one. Please help!!! :)
  • 1 more comment
  • conroe Dec 30, 2007
    Same problem - a plastic piece has broken off of our nexxt 500 washer. It came from the top of the washer opening, just behind the door seal. Unfortunately the 'exploded view' link here does not work.
  • Sanda Jan 03, 2008
    Have the same problem, laundry stuck in dryer and plastic piece is broken off. How do I get drain the load and get the laundry out. What do I need to do to fix the washer?
  • akm3 Jun 05, 2008
    I have the exact same issue. They gray plastic triangular 'funnel' broke off of the inner lip of the washer. Don't know if it is safe to run without it or not.
This is the Laundry defelector. It keeps laundry from getting stuck in the gasket area. If it is broken/extremely worn it needs replaced.
Posted on Jul 31, 2009
  • 944 Answers
Here is a link which shows the exploded diagram for your washer - perhaps you can identify the part; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM and here is the parts list; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM at the top you can order parts direct from bosch. Here is the link to the user manual if you need it; http://www.bshextranet.com/files/techtoolbox/WFMC3200uc.pdf If you have no luck with this then; Best thing you can do is to take a picture of the part and where you think it came from, and either post it again here or e-mail it to your nearest bosch dealer (page 26 of the manual has a phone number). Hope this helps :) ps - if you do contact them, please tell Bosch how good the access to their product literature is - if all manufacturers did this our landfill sites would be half as full - they deserve some praise :)
Posted on Mar 18, 2007
This piece has caught and torn clothing in my washer. Is there anyway to stop this from happening
Posted on Nov 24, 2009
93 Paseo compression 130/50/50/125
check the coolant flow,you know,how in detail it flows. I had a car,Buick I think, that cooling was entering the cylinders,so I checked in total detail how coolant flows and found out it WAS NOT the head gasket but a plastic piece the covered the valley (covered the top of the engine)and it was broken (from wear??)so when I replaced it (some seals),it solved the problem. I'm glad I didn't take the heads off ,machined them,replace head gaskets.....etc. Hope I helped.
Dec 21, 2013 | Cars & Trucks
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
The machine will not spinn, the washing is very wet when finnished washing
clothes are wet after spinning this is due to faulty Motor coupler. test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:If it's spinning when you lift the lid, the coupler is fine.If not then the coupler is broken.It has to be replaced;.This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. ----------------------- If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn motor pulley or tub bearing. Replace the applicable component. Thanks.
Sep 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Haier xqg50 will not dry; It runs the full wash cycle, and will actually run the dry cycle, but the clothes come out comletely soaked. Ran the full 120 minute dry cycle three times, and the clothes were...
Jan 11, 2010 | Haier XQG50-11 Front Load Washer / Dryer
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Spin Cycle Works Some
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Jan 24, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore...no drain but clicks instead...agitates and drains fine 110.92195110
not sur if you found your problem bu I found what was happening with my washer. I pulled the trans and motor assembly out and found a plastic gear / cam broken. I think the part number is 64194. it's found between the clutch and drive to the drum.
Jan 06, 2008 | GE Profile WPRE6100G Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
1,135 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
