Question about Sony MDS-JE480 Mini Disc Player
Need a recording head for Sony MDS-JE510 minidisc deck
I just broke it from it's support. has anyone a solution? where can i find one? thanks
  • 4 more comments
  • udrea_gabrie Dec 15, 2008
    no, it is the magnetic head on the other side of the disc.
    it's HR901 (item no.269) in your drawing
    sorry it's just HR901, 269 is just a screw
    that's the part i need
    thanks!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Are you asking about Optical lens ?
    It is Mini Disc Deck.
  • 10,594 Answers
Please confirm the "Over Write Head" marked in below picture, if this is the case then its part number is as follows...
1-500-396-11 HEAD, OVER WRITE
and available in Part Store on approx $38
Good luck.
Posted on Dec 15, 2008
    Shahid Electronics Dec 15, 2008
    I gave you correct part number for the same, what you posted an image here.
Which mini disc player recorder is compatable with sony mds je480
They are all compatible. Any deck or portable player made by Sony, Tascam, etc.
Feb 20, 2015 | Sony Audio Players & Recorders
Why does the display flash with the word Standby when I switch on?
Some of the decks when first plugged in or powering up need time to get started. I'd wait then press the on button and see if it then turns on.
I get this message on my JA50ES when it has been unplugged or the power went off. It will say standby then you have to push the on button and then it works. I also have this situation with an older Sony Blue Ray Player. My newer Blu Ray comes on fast the older one has a similar situation...
Other possibilities are 510 is just wearing out... The 510 was great but it is an older model. Old units are not worth fixing should this be the case go for a 600 MD Deck (later model) or consider one of the ES Decks. (higher end).
May 14, 2014 | Sony Minidisc Deck Mds-je510 Recorder
Not recording anymore
After you press the 'record' button the Minidisc unit is still in "pause mode" - you can hear the music and see the meters move, but notice that the time isn't moving until you press "Play" - then it will start recording. Is the time changing when you go to play it back? You might have left the MD in 'pause' perhaps?
Jan 30, 2014 | Sony Minidisc Mini Disc Remote Control...
Disc is stopped and ejected prematurely
I've never had this happen. I'd try another disc if it is OK it is probably the disc if not I fear the mechanism is getting worn out. Make certain your mechanism is clean I seldom use the cleaner discs but in this instance I would run it if the problem persists. Using the cleaning discs too often is not a good idea. I've used compressed air to blow out a hair from the mechanism which was messing with the laser in a similar cirsumstance.
Sep 13, 2013 | Sony Minidisc Deck Mds-je510 Recorder
My minidisk deck will not load the cartridge into the mechanism to play
. This webpage will (eventually) show you how to shim the microswitch: http://snnake11.tripod.com/ .
The 510 is from 1998 and is a bit long in the tooth. Later models sound better. Buy a used one from ebay or craigslist. It's easier and cheaper than trying to fix and old one.
And see the MiniDisc Equipment Browser -- http://www.minidisc.org/equipment_browser.html
Oct 25, 2012 | Sony Minidisc Deck Mds-je510 Recorder
Problem with driver on 64bit laptop: need Help
You bought an MD recorder that only records from computers via a proprietary Sony program -- Net MD.
Here is the owners manual - http://www.minidisc.org/manuals/sony/sonysite/MDS-NT1.pdf .
Sony's website will help.
Sep 19, 2012 | Sony MDS-NT1 Mini Disc Player
I have a Sony MZ-M200. I want to transfer live recordings that I have made of my concerts on MD to CD. I can load the recordings into the computer. How do I then burn them onto a blank CD?
You would have to use the Sony MiniDisc software to burn them as a standard CD. A better solution is to buy an actual stand-alone stereo "CD Recorder" and go from the MiniDisc player to the CD Recorder and it will record directly, including track marks if you make it a digital dub! Check into getting a Phillips audio CD recorder, and Sony still makes a stand alone CD recorder as well.
Aug 08, 2010 | Audio Players & Recorders
Sony MDS-JE520 Mini Disc Machine no operation, standby led is illuminated, but pressing on/off button it does not respond
This is from my own experiance. I inadvertedly bent the cover of my deck and had the same error.
The minidisc is blocked in the loading mechanism. Too much weight on top of the deck can bend the cover and the metal support which is above the loading sledge. The slider is then blocked. When you connect the power you can hear a motor trying to move for as short instant.
Disconnect the deck from the power supply.
Take of the cover and check if the support is bent. carefully bend it upwards, if so. Reconnect power and check if the deck powers up..
That's my solution which worked for me.
BTW I second Obertellis advice to find a MDS-JE780 (or MDS-JB980) they are the most complete decks ever made by Sony
Jul 25, 2010 | Sony MDS-JE520 Mini Disc Player
How can i select auto pause on my player model je510 thanks
Inserting blank spaces while recording to tape (Auto Space)
The Auto Space Function inserts a 3-second blank space between each track while recording from MDs to tapes, allowing you to use the AMS function during later playback.
Press A.SPACE repeatedly until “A.SPACE” appears in
the display.
To cancel Auto Space
Press A.SPACE repeatedly until “A.SPACE” disappears.
Note
If the Auto Space Function is on while recording a selection containing multiple track numbers, (for example, a medley or symphony), blank spaces will be inserted within the selection whenever the track number changes.
See Page 21 of your User Manual
May 23, 2010 | Sony MDS-JE480 Mini Disc Player
Sony MDS-JE480 Mini Disc Player Logo
2,181 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
