Question about HP LaserJet 2410 Printer
Takes unusually long before it starts printing
It indicates, Recive data, processing , taking a lot of time
  • manfredchans Dec 15, 2008
    aready tried this
    Genius:
  • 2,785 Answers
Plz try by reloading the printer driver
Posted on Dec 15, 2008
The copy function works very slow. How can I speed it up? officejet 5740.
The reason it is slow is because it scans first, then processes the data and sends it to the printer. The only way that may speed it up a little is to reduce the resolution of the scan. For a document you only need 72dpi, and most scanners with go up to 600dpi -1,200dpi. That takes longer than it needs, as the scanner carrier travels a lot slower, and the data has to be shifted in and out of memory in blocks to be printed, deleted, reloaded and printed. Look in scan settings.
Jan 03, 2017 | Office Equipment & Supplies
What does "100 %" stacked mean?
it means that the printing order for the memory for the printer is full
go to control panel , go to printers and hardware , click on printer right click and it will show a section see what is printing
high light each line and delete that takes away the priority of the stack until there is nothing left to print and the printer should again print at the next selection you make
How the program works is this
there is a small memory in the printer and a large one in the pc
when you have data that is to be printed, the pc sends the data until the printer memory is full at which stage the printer starts to print. new data is sent as memory space becomes available until the document is printed
when different data is requested to be printed or there is a hiccup in the process the pc looses the priority in the print list ( page number or new document)and so backs up that memory and becomes blocked
by going into the pc in the printer hard ware and deleting the printing waiting to be processed your are unblocking the process and allowing the pc to again move data to be printed
Nov 08, 2015 | Brother Office Equipment & Supplies
I have a c734n printer. It prints fine in microsoft word, but when I try to print a photograph, or print something off publisher pro, it takes 10 to 15 minutes before it kicks in.
This is because the word files are very small and only take seconds to process. However the pictures are much more complex and will take a lot longer to be process by the pc and the printer.
However 10 to 15 minutes is far too long. what is the size of the picture in megabytes and at what resolution are they? the higher the resolution the longer it takes. Also your printer is probably set to best picture quality and this too will take longer. You should also think about increasing the ram in the pc as this will help reduce the times.
Jul 31, 2011 | Lexmark Office Equipment & Supplies
It takes 7 and a half minute to print a page. What's wrong. HP Officejet Pro 8500 Premier
It takes 7 and a half minute to print a page....
Depends on many factors my friend:
if u print big amount of data (big color pictures) through wireless connection and the WiFi connection is weak, then it takes time to collect data, evtl. stopping data-transmissions and reconnecting takes awful periods. check ur WiFi connection.
try to connect through USB and test again.
If then printing is normal, ur WiFi is to check, change security evtl. or change location of the printer to strengthen WiFi connection,
good luck
Ganimidis
Mar 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
How do I overcome extremely slow printing, sometimes from an interface with the computer and sometimes just the printer itself?
On a very high resolution setting, a lot of data has to be transfered and that takes time. Sometimes the program generating the data has to re-sample the data which requires massive math work to resize and pixelate the data.
The printer itself may have to do a lot of crunching of the data.
The idea is to lessen the load on the system. Taking a mega-pixel photo from a camera and selecting very high resolution printing can take several minutes just to print one photo.
Nov 10, 2009 | HP Photosmart D7360 All-In-One InkJet...
Allegro2 Print Too Slow (25 seconds send from Windows XP)
miaharoon: Printing via Windows driver it's too long time because the driver sent a lot data to printer. Also the print speed via serial port it's slow. Inside driver, install Datamax printer fonts and barcode fonts to use it in Windows programs.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 22, 2008 | Datamax Allegro2 Thermal Label Printer
TROUBLE PRINTING
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
May 11, 2008 | Sony DPP-FP50 Thermal Photo Printer
Storing music in BOSE 38 system
The Bose uMusic system is a very powerful music management tool. The uMusic storage process involves pulling information from your CD (approximately 3-5 minutes per CD) then storing this information into a buffer area for processing. The buffer area will hold approximately 10 CDs worth of data. After the buffer is full, it must stop taking new data and process the data already in the buffer. The processing time is about 30 minutes per CD.
This means 5 - 6 hous of processing per 10 CDs. So be patient. This is not unusual. Other "media servers" such at Escient and Audio Request take 24 - 48 hours to process a full buffer. There is a lot of data processing going on during this time period and the result is amazing music management once completed.
I recommend clients load 10 CDs in the morning and let it process till after lunch. Then another 10 CDs and let it process until after dinner. Then another 10 CDs and let it process overnight. This routine completes 30 CDs per day.
If you have 100 to 400 CDs an automated services is available from HouseSys.com. This is the only automated service available for this system.
Jan 20, 2008 | Bose Lifestyle 38 System
HP LaserJet 2410 Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
