Question about Taiwan Semiconductor Co. TSC TTP-243 Thermal Printer
Sharing problem in tsc ttp 243
I HAVE A PROBLEM REGARDING TTP 243 MAKE TSC WHEN I GIVE THE COMMAND THRU SHARED COMPUTER WINDOWS GIVES THE MESSAGE " TSC TTP 243 PRINTER DRIVER IS NOT INSTALLED" EVEN I HAVE INSTALLED THE DRIVER ON CLIENT PC ALSO. PLS HELP ME IF ANY HAVE THE SOLUTION.
  • Anonymous Apr 17, 2009
    i need a driver for my tsc 243 ttp plus
How to Share Files on SugarSync Manager on Windows?
Run SugarSync Manager and log in
Navigate through your files and folders under SugarSync until you find the folder to use for collaboration. To navigate folders, just double-click on the folders.
Right-click on the folder. This will bring out the context menu.
Go to "SugarSync" and select "Share." The Share window will appear.
Click on the "Share Privately" button on the left of the Share window. Only people you invite will be able to join this private shared folder.
Choose the recipients. Under the Recipients box, type in the email addresses of all the people you want to share this folder with. These people will need SugarSync accounts in order to join your shared folder.
Add a personal message. There is a text box under "Recipients" where you can add a custom or personal message to welcome them and give them a background of your folder. This is optional though.
Send the invitation. When you're ready, click on the "Send Invitation" button. An email will be sent to your recipients inviting them to join your shared folder. Once your recipients accept the invitation, your shared folder will be created, downloaded, and synced on their computers.
Oct 20, 2016 | Microsoft Computers & Internet
Usb 8Gb drive gives "The disk is Write protected" error message.
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
Jan 07, 2013 | Transcend (589307) Media
How to replace the printhead of Clever TTP 244 Plus
Call TSC Orlando office 407-704-8918 for tech support
May 14, 2010 | Taiwan Semiconductor Co. TSC TTP-243...
My TSC TTP-245 label printer does not print complete
por fabor necesito las claves de tsc ttp-244 plus pues se me perdieron
May 11, 2009 | Taiwan Semiconductor Co. TSC TTP-243...
Networking with windows
Hello there.
Nice to see more people using Linux and Ubuntu. For information on how to share your Ubuntu folder to linux, over file sharing click here
You basically only need to right click the folder you want to share, in Ubuntu, then enable sharing and when prompted to install services, tick the box called 'Install Windows network support'
Hope this helps.
ps: if you haven't seen the Ubuntu community documentation, click here
Apr 13, 2008 | Computers & Internet
Error 5
hi
check the permission of the share and also you may have to create a user just for sharing
This is a permission issue. If the net view command fails with a "System error 5 has occurred. Access is denied." message, 1) make sure you are logged on using an account that has permission to view the shares on the remote computer.
2) Need to cache credential: logon the same username and password on both computers or use net net use \\computername /user:username command.
3) Make sure the Netlogon service is running
the second question : it is a spyware
check this link in regards to clean t
Feb 13, 2008 | Microsoft Windows 2000 Professional for PC
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Taiwan Semiconductor Co. TSC TTP-243 Thermal Printer Logo
204 people viewed this question
Top Taiwan Semiconductor Co. Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Taiwan Semiconductor Co. Office Equipment and Supply Expert? Answer questions, earn points and help others
