Slider Kyocera SE47/ Portable Handsfree Kit Headset
Problem for Slider Kyocera SE47/ Portable Handsfree Kit Headset
What is frequency response, and why is it important?
By pawa - usenet poster
Best Solution
posted on Sep 17, 2007
Very Helpful)
kaif
Rank: Apprentice
Rating: 100%, 1 votes
I use jabra Bt250v ,there ia a terrible disturbance like cracking noises .I tried to re-pair it many times,but the sound persisted.I sound is on and off.I paired it with moto razer and t mobile MDA but the sound persisted.Any help would be appreciated.
Was this helpful?
Yes
No
Solution #2
posted on Aug 25, 2007
Helpful)
onisomroy
Rank: Guide
Rating: 70%, 28 votes
Frequency response in audio product statistics is used as a measurement for how well that piece of hardware/software will reproduce the audio as the audio engineer intended.
There are two things to look at concerning frequency response.
1) What is the range? (20hz - 20khz)?
2) What is the accuracy (+/- X db)?
Humans have an audio response range of 20hz - 20 khz. The closer a product is to these numbers, the more accurate, and therefore better, it is.
Second, you must look at the accuracy. This detail is left out of many consumer products but you will find it in higher-end products. This second statistic (+/- X db), is very important however. Just because a product picks up between 20hz - 20khz doesn't mean it's any good. For example, if it has say +/- 30db because it will pick up the best frequency 30db better than the worst frequency. Technically, the best numbers for this value should be +/- 0db.
However, not everyone loves such an accurate response of +/- 0db because it may not "sound good." For example, when you get some blasting subs in your car, you're actually adding anywhere between 5db - 10db to the bass frequency response (depending on how loud the subs are).
The bottom line is, frequency response rates the accuracy of audio reproduced compared to its original state.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 08, 2005
Helpful)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
Frequency response is a specification which, in headphones, describes how well the headphone reproduces the range of audio. The frequency response describes those frequencies that the headphones can acceptably reproduce.
Was this helpful?
Yes
No
Popular Solutions for Slider Kyocera SE47/ Portable
Questions and Unsolved Problems for Slider Kyocera SE47/ Portable
Do you recommend Slider Kyocera SE47/ Portable Handsfree Kit Headset?
Answer
Answer
I have lost the manual for my emerson em227 headset. How do I get it connect.
Answer
I'm plugging in my mic its a usb one, and its acting like nothing is there and I can't hear anything... (More)
Answer
My mike does not work properly when i talk my voice is scrambled up and my friends can not... (More)
Answer
Stuck in headset mode with my Samsung R450 phone. It sucks! Any help???
Answer
I got this phone about a month ago & also just bought a fm transmitter. I think the fm... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Slider Kyocera SE47/ Portable...:
Top Headset Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Headset Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
