Question about Microsoft Windows XP Professional
Microsoft Excel How Many Worksheet could we added in excel ?
    President:
  • 1,901 Answers
The number is only limited by the physical memory of your system. Add away! :-)
Posted on Dec 15, 2008
How to delete a header/footer in excel 2010?
To remove the header or footer text from Excel 2010 worksheet, you can follow the instructions below:
1.Go to "Insert" tab and then go to "Text" section.
2.Click "Header and Footer"
3.Click the left, center, or right header or footer text box at the top or the bottom of your worksheet page.
(Note: Clicking any text box selects the header or footer and displays the "Header and Footer Tools", adding the "Design" tab.)
4.Press "Backspace" or "Delete" on your keyboard.
To know more about removing header and footer, you can refer to "Remove the header or footer text from a worksheet" section on the following Microsoft support page:
http://office.microsoft.com/en-in/excel-help/use-headers-and-footers-in-worksheet-printouts-HP010342991.aspx#BMremoveheaderfootertext
Hope this will help you.
GuruAid.com
Sep 03, 2014 | Microsoft Computers & Internet
Tip
How to find no. of rows and columns in Worksheet.
Hello everybody, this would be my first tip on FixYa.com. Number of people might not be aware how many rows and columns are there in Microsoft Worksheet.
This is how you can find out.
1. Select A1 cell in the worksheet
2. Now press Ctrl + down arrow from your keyboard, that will take you to the bottom of the row. You can find the number on the left side.
3. Again select A1 cell in the worksheet and press Ctrl + left arrow from your keyboard, that will take you to the last column of the worksheet. Now to number, just type "=column() " , without quotations, that will give you the number of the column.
Microsoft Worksheet columns is number from A to Z, again from AA to AZ, again from BA to BZ and so on till it reached IV in Excell 2003 and earlier version.
Microsoft Excel 2003 and old version has 16,777,216 cells per worksheet (65,536 rows * 256 columns).
Excel 2007 has 17,179,869,184 cells per worksheet (1,048,576 rows * 16,384 columns).
on Jul 27, 2010 | Microsoft Excel for PC
My excel is starting right to left in window 7
The default worksheet direction in Excel 2007 or 2010 is Left-to-Right. To change a worksheet direction to Right-to-Left, follow these steps:
  1. In Excel Ribbon click on the Page Layout tab.
  2. In the Sheet Options group click Sheet Right-to-Left. The sheet direction will be changed. Column A will now be to the far right. Columns B, C, D.. etc. will follow to the left.
- See more at: http://www.exceldigest.com/myblog/2012/04/29/how-to-change-worksheet-direction-in-excel-2010-to-right-to-left/#sthash.lSG25YXq.dpuf
May 27, 2014 | Microsoft Excel 2010
What is default name in ms excel? how is possible excel worksheet in excel?
Book1.xls Do you mean that you can't find the worksheet you have establish and you haven't rename the file? The worksheet will be OK if it had been saved.
Feb 15, 2011 | Microsoft Office 2010
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Jun 10, 2008 | Microsoft Office Access 2003 (077-02871)...
Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
Apr 25, 2008 | Microsoft Office Professional 2007 Full...
PASSWORD RECOVERY
Try to Recover Excel Password with Excel Password Recovery 5.0. I have searched MS Excel Password Recovery, found this efficient Excel Password Recovery program. It supports all versions through 97 to 2007.
Remark:
Office Password Recovery tool also can help! It recovers Password to Open and removes both the Password to Open and Password to Modify for Microsoft Word, Excel, Access and PowerPoint of versions through 97 to 2007.
Feb 18, 2008 | PC Chips M825G Motherboard
Micosoft Excel
33
34
35
36
ii I i]\sheet1 sheet2
click ^ or ^
Bottom left corner of workshet
Nov 29, 2007 | Microsoft Excel for PC
Microsoft Windows XP Professional Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
