Question about Acer Aspire 5100 Notebook
Computer locking up
When I use a usb storage device my computer locks up. When I use any thing else it does not recognize it.
  • 91 Answers
Sounds like a corrupted file in windows. A reformat will fix this most likely..
Posted on Dec 29, 2008
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
Baby lock ellure plus
Can you elaboate more on the issue
Apr 06, 2008 | Baby Lock Ellure
My memory card for D3000 is locked but i checked the card, it seems like the lock is not there how do i sort this out?
Oct 19, 2012 | Nikon D300 Digital Camera
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
Pics wont down load to PC
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
Apr 22, 2012 | Panasonic Lumix Dmc-fs12 black 12.1mp 4x...
How do i connect my gt-s3650 samung phone,using usb lead to upload photos from phone.
You can try two things.
1. Download Kies the software to be used for file transfer in samsung...install that connect the device..it will recognize it.then you can move the pictures to the computer
2. Go to settings inside the phone....check pc connectivity there and select mass storage.
so now when to connect th phone the computer will recognize the phone as external mass storage device..simply go to my computer and then open there
Aug 18, 2011 | Samsung Computers & Internet
I Using Like USB Storage ,After my Use i done Antivirus Scan then Not apparing And not working Only Blinking Light
Reboot your pc. Check again.
If it's still not working, check if your hardware is recognized: [Windows] Right click on My Computer (on your desktop or in your start menu), then properties. Go to device manager Check if your USB stick is located under USB devices.
If its recognized, check if there is a switch on the hardware itself it that locks it.
[ONLY FOR ADVANCED USERS]: If there is no lock as mentioned above, try to re-initialize the partition using the disk management: http://technet.microsoft.com/en-us/library/cc782513(WS.10).aspx
Apr 28, 2011 | Computers & Internet
I have a nokia n95 china clone on the board D800 v0.2 printed.when i conect with usb cable computer says device not recognize.what is this.help me plese.thanks
It means that the phone should be recognize as mass storage device, if it doesn't recognize it, you can try by restarting the PC with the phone connects to the computer, when the computer boots, it should be recognize as Mass Storage Device. You need no driver.
Nov 09, 2009 | Nokia N95 Cellular Phone
My computer locks up when i use a usb port for storage devices and does not recognize any other usb devices
I suppose this can be a security measure to block all storage device if its in office premises , if the same happens in home then you will be running an antivirus in which you need to enable the access .
Dec 15, 2008 | Acer Aspire 5100 Notebook
GPX MW6815DT trouble
For those that still use this mp3 player here are some things you need to know.
the gpx mw6815dt can operate as a media player or a usb storage device.
you need to change which state it is in via the System option.
Enter (Sys) from (Mode) go to (Online Device) enter (Mode) select USB Disk or Media Device. When you connect it as a USB Disk you will see all files not shown when connected as a Media Device using windows explorer. Also I suggest you make sure if you format the GPX you stay with the FAT 16 file system.
Note: DRM only works when the gpx is in Media mode.
If you have an SDcard installed you can access it via windows explorer or media player as a usb device only. With media player 11 you can still sync both the internal and sd drive with your library however you won't have drm options since your in usb device mode.
Note: in order to have both usb drives avaiable you need to use the Multi Drive option under (Online Mode) in the (System) menu, other wise you won't see the sdcard.
Feb 15, 2006 | GPX MW6815DT MP3 Player
Acer Aspire 5100 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
