Back to:
Tags:
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Cannot recieve faxes (by 7 users)
posted by Luisa on Apr 01, 2007
when people try to fax me the fax does not come through. my answering machine is set on 5 rings, my voice mail is set on 4 rings and the fax is set on 3 rings. I have been on the phone with lexmark tech support. we set the all in one printer back to factory settings and the tech sent me a test fax. When my sister tried to send me a fax it did not work.I can send a fax but not receive a fax
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by powersp, posted on Jul 23, 2008
Yes, I have the same problem with the x8350 I purchased late last year. Also I have another big problem when copying. The machine makes lots of noise and quits printing until I turn it off and then on again. Soon I have the same problem continuing.
Comment by jerryypa, posted on May 02, 2008
cannot receive a fax
Comment by Guest, posted on Mar 26, 2008
cant receive any faxes
Comment by Msbey, posted on Dec 28, 2007
I have the same problem. I have followed the directions to the letter. I have no problem sending but cannot receive.
Comment by NancyRuth, posted on Dec 12, 2007
same problem. I can send faxes fine, but cannot receive properly. I have an answering machine set to 5 rings, and fax set to pick up after 3 rings.
Best Solution
FixYa! (100)
Msbey
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on cannot recieve faxes:
I don't want to Accept this solution
Solution #2
posted on Aug 26, 2007
Helpful (85)
LexBrett
Rating: 81%, 7 votes
Read the manual Page 95. What I want to know is how to make it pick up on more than 5 rings. The X8350 presets max out at 5 rings, not enough time if you have 2 story office and an answering machine in the loop.
Thank You!
Can you Help with these Printers problems?
Lexmark X8350 Print, Scan, Copy and Fax...
I've selected Clipboard...pic shows...then...
how do I retrieve scanned pages from my fax when the fax...
Whenever I try to scan, I get a "Scan Was Not...
I'm trying to download from lexmark the driver. the pc...
I changed the ink catridges in my printer but it will not...
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 03, 2007
can not send or recieve a fax
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
