Question about Acer Aspire 5100 Notebook
My computer locks up when i use a usb port for storage devices and does not recognize any other usb devices
    Guru:
  • 829 Answers
I suppose this can be a security measure to block all storage device if its in office premises , if the same happens in home then you will be running an antivirus in which you need to enable the access .
Posted on Dec 15, 2008
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
"little tikes- my real camera" can't upload pics
The USB connection seams to be very sensitive try pushing the USB cable into the camera firmly and wiggling it. Once the mass storage device is recognized be careful not to move the plug. The connection can be very flaky.
Good luck,
Mike
Dec 10, 2008 | Little Tikes My Real Digital Camera Pink
Olympus E510
Make sure the camera is on and STORAGE is selected on the camera screen when connected to the computer. You will need to have STORAGE highlighted and select OK on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Aug 01, 2008 | Olympus Cameras
USB Ports don't recognize typical thumb drive, mass storage devices
I'm not completely sure, but this may be a result of faulty drivers.
Try googling the brand name and the word: "Driver"; along with any other details about the device. (Model No. et cetera.)
Jul 31, 2008 | Computers & Internet
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Buffalo USB 25gb external hard drive
There is probably just a bad connection between the usb and hard drive. Unplugging it and plugging it back in. If that doesn't work try another usb port. That usually fixes the problem.
Aug 23, 2007 | Buffalo Technology (DHHSD10TGLR5) 250 GB...
Acer Aspire 5100 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
