Question about Raymarine C80 GPS Receiver
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and Screen I would like to to which each of these should be connected if at all. OR should I use the Seatalk connection. If I use the Seatalk then do I use the NMEA for the Autohelm Roger
  • 111 Answers
I would send your seatalk (Yellow and black) from your c80 to a junction box, send your rs125 to the junction box and another pig tail seatalk lead to the J-box coming from the autopilot. Now...on the raystar 125 connect the green wire to red, and the brown to black. Now connect the reds together, the shields and blacks together and finally the yellow's. The autohelm should power up the seatalk bus enough for your gps to work. the c80 offers power from seatlk but don't connect it's red wire.
Autohelm ---------------[ ]----------------GPS
Many times the shield is the silver wire we call it that since it has no other coating except its occasionally heat shrinked on the end.
RS125 -------Green------------------------0-------------RED------------ + power
--------Yellow-----------------------0-------------Yellow---------- Data
--------Black------------------------0-------------Shield----------- -Power
Posted on Jan 22, 2010
    Problem Solver:
  • 14 Answers
You can use either NMEA or SeaTalk to connect the GPS, iand you can use the SeaTalk for both GPS and pilot.By using SeaTalk you will also supply the GPS with 12V directly.
SeaTalk Connect:
(plotter) yellow - yellow (gps)
(plotter) red - red&green (gps)
(plotter) black/grey - black/grey (gps)
And for pilot connect color to color.
Posted on Sep 23, 2009
    Problem Solver:
  • 10 Answers
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Posted on Jun 15, 2009
Wiring to standard horizon eclipse GX 1 300E
It is more than likely green and yellow for one and blue and brown for the other with white being redundant ground.
May 04, 2016 | Cars & Trucks
Rs125 seatalk to st6000+
An RS125 can be connected to a ST6000+ with either NMEA or SeaTalk data connection. NMEA is easier IMO.
To connect via NMEA, the RS125 red wire would go to vessels +12 volts. Yellow would be connected to the NMEA+ on the back of the ST6000+ and the shield, green and brown would be connected to the NMEA - on the back of the ST6000+ display
When connecting your RS125 into an existing SeaTalk network it should be powered from the network and not the display. The red and green of the 125 connect to the course computer SeaTalk red. The yellow cable should be connected to your display SeaTalk yellow. Shield and brown of 125 should be connected to SeaTalk gray.
Page 4 and 5 of the RS125 manual have pictures. PDF File
Feb 22, 2012 | Boating
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
I just bought a raymarine c 70 with an evermore sa 320 gps, can anyone help with the wiring i have to do as i seem to have misplaced the instructions which came with the sa 320.
them works together nice !
connect SA320 green wire to RAY white and SA320 shield(black cover) to RAY green.SA320 red to 12 and black to ground(-).
Jul 21, 2009 | Raymarine GPS
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Proper wiring for gps
red and green go to 12v.brown and screen go to earth yellow to yellow.
Apr 23, 2009 | Raymarine C80 GPS Receiver
GPS antenna
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
Jun 04, 2008 | Raymarine C80 GPS Receiver
Raymarine C80 GPS Receiver Logo
736 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
