Question about Sony Cyber-Shot DSC-T1 Digital Camera
Digital Camera blurring
When I turn the camera to take pictures or recording mode, it shows me vertical lines going down a red blurry image and appears that way when I take the picture. However, when I go to view the pictures I've taken previously before I have this problem, they are show perfectly fine.
I've had it for two years, but only occasionally used, if that helps any. :|
I'm not sure what's causing it, or what to do.
  • pbkking3 Dec 15, 2008
    i have exactly the same problem and dont know what to do
  • 10,594 Answers
It is problem of bad CCD imager IC and this part needs to be replaced.
Sony will repair it free of cost as per announced scheme for this problem in DSC-T1 Camera.
Please click on Sony CCD Support for details. If you are in other country, let me know to guide you more.
Posted on Dec 15, 2008
Canon powershot a470 vertical lines, white picture, blurred
The image sensor is defective. There is no quick fix other than replacing the image sensor.
May 13, 2017 | Canon PowerShot A470 Digital Camera
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony DSC-T1 Camera - Blurry display and picture
Its bad ccd imager problem in DSC-T1 and ccd imager will be replaced.
Sony will repair your camera free of cost for same problem as per announced scheme.Only $20 for shipping charges.
Click Sony CCD Support for details.
Apr 08, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon s200 digital elph will take the pic but it is all blurry, was working fine previously
Hey ednjoey2007,
The most common cause of blurry images is the camera moved during exposure so make sure to hold the camera as steady as possible. Another common cause of blurry images is caused by not holding the shutter button halfway down to achieve focus, and then press the button all the way down to take the picture. Another cause of blurry images on this camera is the AF assist beam is either blocked or set to off, and lastly if your subject is too close to the camera (closer than 1.9ft) your image will come out blurred. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 12, 2008 | Cameras
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Vertical and blurred imagery
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Sep 16, 2007 | Canon PowerShot A75 Digital Camera
Vertical lines in screen / Blurry pictures
Hi there, please check this link: http://www.imaging-resource.com/badccds.html Sony will repair your camera free of charge. Best regards, Arpi
Jun 20, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Help
Do the pictures have lines across them as well as being blurry? If you see the lines then your shutter is stuck open and it will require repair. The shutter has to close for the image sensor to properly record the image. If they have no abnormal lines on them, are they "out of focus" blurry or is it more of a streaked motion blur kind of thing? If you do need to get the camera repaired you should check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Feb 27, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
63 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
