Question about Whirlpool Duet GHW9150P Front Load Washer
Washer stopped during cycle
I started my front loader on the heavy duty cycle. After about 4 minutes it stopped and the timer started flashing. I also noticed all the lights on the left side ("add garment," "rinse," "door locked," etc) were not lite. I pressed pause cancel and the machine drained the water and allowed me to open the door. When I tried restarting it, nothing happened. The lights on the left still are not lite but the ones on the right are. I unplugged it and plugged it back in and still nothing! It is not even a year old yet!
  • Anonymous Mar 18, 2014
    The circuit breaker for the machine popped. When I reset the breaker the machine was in the spin cycle. It won't complete the cycle. I have flipped the breaker off and attempted to set the washer to the rinse and spin cycle, it added some water but would not spin. The add a garment and door lock light stay lit when I attempted to open the door by pushing the start/Pause button. The panel becomes dead at this point. I have flipped the breaker off and left it off for more than 5 minutes but the washer won't restart or open the door.
    Scholar:
  • 76 Answers
Cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Posted on Mar 22, 2007
  • Jake2771 Jan 05, 2012
    I also have this problem and am under warranty but the contracted servicemen cannot solve the
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Mar 21, 2010 | Hoover HTC243 Top Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Mar 14, 2009 | Amana Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
415 people viewed this question
Dan Webster
Dan Webster
Sal De
