Question about Sony UPDR150 Thermal Photo Printer
Sony UP-DR150 4x6 "ribbon error"
When I load the 4x6 ribbon and close the machine it gives me a "ribbon error" and will not let me print. I opened up the package and used a new ribbon and it gave me this error. I also tried on the other brand new 4x6 packaged ribbon and gave me the same error. Then I tried with a 5x7 ribbon and it worked. The problem is I want to print 4x6 prints. Can anyone help me solve this problem and if not who to contact.
thanks
aaron J
  • ajetelina Dec 15, 2008
    found solution. Just needed to upgrade the software in the printer. Thanks Aaron J
  • boomertran Dec 26, 2008
    i have the same problem when i bought a new roll of paper and ribbons that has the "H" at the end of R154.  and i am using Mac.  Please help!
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Posted on Apr 14, 2009
The paper and the ribbon are matched. I dont think that you can just change the ribbon. You may have to change both the paper roll and the ink ribbon.
Posted on Mar 21, 2009
Open Door Error Sony Up DM150 Printer
The door closes onto a micro switch. I suspect there will be your fault.
Mar 01, 2017 | Office Equipment & Supplies
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Z110xilll after 3or4 labels paper out error
Please run manual calibration
(take 2 or 3 labels and load the labels under the printhead and sensors, close printhead, press enter,
if ask for "take the ribbon," just open the print head, take the ribbon out from the sensors, close printhead, enter.
then if ask for load media, just put everything like you normaly setup the printer and press enter. The printer gona run the calibratio, Please close the door case, this can afect the sensors data.
save
tur off the printer and back on again.
run sensor profine. check if sensor check the gap (smal mountan )
Nov 12, 2010 | Zebra 110Xi III Plus Thermal Printer
Error print head open on Zebra 6m plus. Load ribbon and stock close head and it will start to calibrate then the error print head open comes up. 2 new sensors have been installed by a Peak tech. Is there...
The sensor on this printer is a double sensor. The side close to the frame is the head open and the one on the outside is the ribbon present. It is adjustable. They both reflect off the chrome surface of the head assy. above them. First clean the chrome surface above the sensor and test before adjusting. There is one screw that you can loose and tilt the sensor to match the angle of the chrome plate above. Also the gap between the sensor and the chrome surface is .060in. or 1.5mm.
Oct 19, 2010 | Zebra Z6M Plus Thermal Label Printer
Error condition head open
First test this: remove the ribbon close head if the error goes away it is not your sensor. Most of the time someone has loaded the ribbon on a little to hard and broke the plastic tab that insure it loads correctly. With the tab gone you may get lucky and load it right sometimes and other times not this is why some ribbons work and some do not.
Aug 04, 2010 | Zebra Z4M Printer
A cd is stuck in 5 cd player. Drawer won't close. (Sony) When drawer did open/close, it just started making a noise - maybe belt wearing out.
Without knowing the model number, this is pure speculation:
There are some Sony units that can easily get "out of time" in the loading mechanism. This can be caused by a broken trace in a ribbon cable or a defective sensor. Some models can get out of alignment or timing if you push the drawer rather than pushing the close button. Please update this with the model number, and I should be able to give you more details.
Thanks,
Dan
Oct 01, 2009 | Sony Audio Players & Recorders
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
Sony UPDR150 Thermal Photo Printer Logo
1,305 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
