Question about Acer Aspire 3690-2196 Notebook
What to rebot 2 fact specs
Freezes, runnin slow.
Try to use the disk cleanup, check your antivirus updates and then make a full system scan, uninstall the unused programs, clean the startup section by using Start-Run-msconfig-startup and remove the selection about some programs you won't to start with startup!!!
check your disk drives (check disk)
after all this make a defragmentation
Posted on Dec 15, 2008
Y is the game the crew runin slow i have error code #0_0
Jan 30, 2015 | Ford Cars & Trucks
Fix Hotmail slow and freezing
Any ideas why Hotmail freezes? This is a serious problem for Hotmail users. You can not bear the free e-mail gets slowdown and freezing, so you are looking for a way to solve it? The tips provided by our computer technicians can help you get rid of the problem in minutes. Follow me and read the guide to fix Hotmail slow.
Tips 1
When the problem occurs, you should open the Task Manager and end the frozen page. Many e-mail slow problem due to temporary Internet Files. They are the garbage you never need.
Manual removal Temporary Files and caches
1 Click Tool to drop-down the menu and select Internet Options.
2 Click Settings on the General tab.
3 The Delete File button enables you to remove junk items such like Temporary Internet Files, Cookies History, etc.
Tips 2
DNS is short for Domain Name System. DNS was designed to deal with the IP address you type in. Cleaning it is easy, just visit How to clean up caches and registry.
Hotmail freezing not only caused by junk files but also due to IE browser version incompatible. Check your browser update and download the latest version.
Other causes of Hotmail freezing and slow
If ActiveX controls and plug-in are not enabled, the webpage may hang up. To enables ActiveX controls and plug ins, you should go to Tool > Internet Options > on the Security tab, select "Internet" >choose Custom Level > From the "Security Settings to enables the setting.
Occasionally, virus installed on your computer without your permission. It can change the setting of your computer by modifying the registry. Fixing it is easy, ErrorFix was designed for users with no computer savvy. They can clean up registry without the help of technical personnel. In fact, ErrorFix has the ability of fix all errors above. Have a wonderful experience of fixing Hotmail slow and freezing now.
on Sep 15, 2010 | Computers & Internet
I have a suzuki samurai that my grandfather gave me and he wants to keep it in the family. its a 85 and the it wont stay runnin. to keep it runnin u have to pumpin the gas or put gas in the carb. any...
all engines.
good compression
good spark , strong to all 4 cylinder, and timed by the fsm need a free fsm see links.
last is fueling if above is good ,now a carb can begin to work right.
if not flooding, (is it) then its starving.
ill pretend starving.....
1: fuel pressure at spec.
2: float level at spec.
there are 50 more carb checks but Ill stop here.
now the link to a real fsm. for free.
Mar 08, 2013 | Cars & Trucks
Why is my computer runnin so slow and freezing can this be fixed
If we knew the Make, Model of laptop and the OS we could help you.
Mar 05, 2013 | Computers & Internet
I have a 1982 yamaha vision 550 i have it runnin but hard to find a smooth idle choke to high idle real fast choke to low it dies
Hi, Renee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Owning Vision FAQ
Hard starting can open choke
Yamaha XZ550 XZ 550 1982 1985 Factory Service Repair Manual Download...
OEM parts for Yamaha
Yamaha XZ550 Vision Carburetor Overhaul Pt 1 Getting Started
Jul 15, 2012 | 1982 Yamaha XZ 550
How do i rebot the nokia x3 2?
please clarify the problem
Mar 30, 2012 | Nokia X Cell Phones
What do I need to do to speed up my Dell E1505 Laptop, it's running slow
A slow Dell laptop can be caused by many many reasons such as outdated hardware, overload start up programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do the job manually, try the Dell speed up solution available here: best regards!
Feb 27, 2012 | Dell Inspiron E 1405 E 1505
I have a nokia 5130c-2 every time I power it on the phone's keypad freeze and it rebot again. Can you please help me solve my problem. Cheers
Try removing the battery for about 30 seconds. Your battery could also be almost dead and need replacement - especially if it's more than a year old. You can get replacement batteries very cheap on ebay.
Apr 17, 2010 | Lands Phones
My netbook runs slow and freezes
There are many reasons for slowness and freezing. Computer specs (ram, processor speed, connection speed)) could be not enough for today's internet.
Internet cache, temporary internet files, temporary files should be cleared.
Try defragmenting the hard drive.
And try downloading a program like CCleaner from Piriform.
Apr 10, 2010 | Computers & Internet
Injector plugs
if u put a bulb across the contacts thhe bulb will light when cranked to show there is power there thr it on each 1 , if no light then there is no power or signal to the injectors
Jun 05, 2009 | 1988 Chevrolet Cavalier Z24
Acer Aspire 3690-2196 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
