Question about Fisher Paykel EcoSmart GWL15
Smart drive 5.5 washing machine lights show power on but no go
Fisher and Paykel Smart drive 5.5 washing machine lights show power on but no go
  • joseph70 Jan 01, 2009
    Same problem with F&p model LW095NZ.  Poer's upOk & goes through test cycle OK.  Turn power on & select wash options, press start & nothing!
  • 351 Answers
SOURCE: Fisher and paykel smart drive... Water does not go in
check the reed switch under the lid (magnet) and the cold water may be just a cold valve they get slow flow common problem
Posted on Mar 02, 2008
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
ginko
  • 19396 Answers
SOURCE: Fisher & Paykel smart drive
It is either the inlet valve or the pump. If the pump is fine you need to replace the inlet valve. Here you can find parts.
Posted on Jun 08, 2008
ngfam1
  • 639 Answers
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Posted on Dec 16, 2008
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
FISHER & Paykel 6.5 Smart Drive - No display lights
You need to get hold of a multi-meterand check the resistance of the pump, It should be 33ohms or close to it, the pump is part of the power circuit and the machine will appear dead if it has blown or is unplugged, If the machine was running without the earth wire to the pump connected and the pump had a fault/blockage there is a very good chance that it has blown the motor controller module. It requires the earth to provide a fault path to earth.
Mar 03, 2012 | Fisher Paykel Eco IWL16
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Jun 08, 2008 | Washing Machines
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Apr 15, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Jan 17, 2008 | Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
122 people viewed this question
Top Fisher Washing Machines Experts
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
