Question about Raymarine C80 GPS Receiver
Can I connect RS 125 to C80 using NMEA 0183
The white cable from the RS125
To connect by NMEA 0183 (Shield, Green, Brown, Yellow, Red)
The NMEA pigtail to the C80 Plotter has ( Green, White, Brown, Yellow and Shield)
Can you please advise which colour wires should be joined to each other.
  • Anonymous Apr 28, 2009
    Did you ever solve your problem
    I have the same issue
2 Suggested Answers
  • 111 Answers
SOURCE: I bought a C80 Raymarine
I would send your seatalk (Yellow and black) from your c80 to a junction box, send your rs125 to the junction box and another pig tail seatalk lead to the J-box coming from the autopilot. Now...on the raystar 125 connect the green wire to red, and the brown to black. Now connect the reds together, the shields and blacks together and finally the yellow's. The autohelm should power up the seatalk bus enough for your gps to work. the c80 offers power from seatlk but don't connect it's red wire.
Autohelm ---------------[ ]----------------GPS
C80---------------------------
Many times the shield is the silver wire we call it that since it has no other coating except its occasionally heat shrinked on the end.
RS125 -------Green------------------------0-------------RED------------ + power
--------RED------/
--------Yellow-----------------------0-------------Yellow---------- Data
--------Black------------------------0-------------Shield----------- -Power
--------Brown---/
Posted on Jan 22, 2010
Wiring to standard horizon eclipse GX 1 300E
It is more than likely green and yellow for one and blue and brown for the other with white being redundant ground.
May 04, 2016 | Cars & Trucks
Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Jul 05, 2012 | Garmin Fishfinder 90
Rs125 seatalk to st6000+
An RS125 can be connected to a ST6000+ with either NMEA or SeaTalk data connection. NMEA is easier IMO.
To connect via NMEA, the RS125 red wire would go to vessels +12 volts. Yellow would be connected to the NMEA+ on the back of the ST6000+ and the shield, green and brown would be connected to the NMEA - on the back of the ST6000+ display
When connecting your RS125 into an existing SeaTalk network it should be powered from the network and not the display. The red and green of the 125 connect to the course computer SeaTalk red. The yellow cable should be connected to your display SeaTalk yellow. Shield and brown of 125 should be connected to SeaTalk gray.
Page 4 and 5 of the RS125 manual have pictures. PDF File
Regards
Feb 22, 2012 | Boating
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
Proper wiring for gps
red and green go to 12v.brown and screen go to earth yellow to yellow.
Apr 23, 2009 | Raymarine C80 GPS Receiver
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
GPS antenna
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
Jun 04, 2008 | Raymarine C80 GPS Receiver
GPSMAP 180 power/data connector
Okay
guys: book says:
PIN 1 (red) 10-40 volts DC
PIN 2 (black) Ground
PIN 3 (blue) NMEA out Shows this goes to Autopilot/NMEA devise and to RXD positive RXD negative goes to ground (black)
PIN 4 (brown) NMEA in Goes to GBR 21 Beacon Receiver to a blue wire, brown wire on thaat devise goes to PIN 3 and the negative goes to ground
PIN 5 (white) no connection
PIN 6 (Green) no connection
PIN 7 (yellow) goes to alarm low Shows going to negative terminal on alarm relay and positive terminal goes to PIN 1 (red)
All Greek to me, have fun
Seadrive Joe
Feb 03, 2008 | Garmin GPSMAP 180 GPS Receiver
Raymarine C80 GPS Receiver Logo
175 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
