Question about Fisher and Paykel GWL11 Top Load Washer
Fills slowly and does not max spin
I am actually enquiring about the GW 703. It appears to function but for the fact that it fills very slowly. I can ocasionally detect that it BEGINS to fill normally but within a short time it reverts to slow fill. And it also spins below the max speed. The filters have all been checked and are clear. There is a setting somehow attained by presssing various buttons in particular sequences that resets the machine's micro-processor. I have used that in the past but now lost the sequence.
We found that there was a controlling switch "thingamebit" that sets the water coming into the machine, and a part was just replaced. The part cost $40 but the service cost $90.
Posted on Apr 01, 2007
Why is my samsung fuzzy fully automatic washer, WA167HA1, not spin drying properly my clothes still remains drip dry
Cut back your detergent. Too much can mess with your pressure sensor and causr incomplete spins. Never fill to thr max line.
Nov 25, 2014 | Samsung Washing Machines
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
There is always water in the drum even after a laod but after it sits empty the tub fills with more water
This might be a problem with your locking mechanism which is preventing the washer from actually performing a complete spin cycle. It will drain and appear to function but the high speed spin never actually takes place.
Aug 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
178 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
jimorris77
shaun taylor
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
