Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
I have a dishlex global 450. it shows ND. what does this mean? It also has water at the bottom of the dishwasher.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, error message "ND" refers to "No Drain" and therefore would require that the drain system be checked, cleaned and inspected for any faulty components. Normally, there would be a drain filter, a sump or sorts, a valve, an impeller and a pump that leads to the drain hose. Access to these components would be through removal of the bottom/kick panel. Further the presence of water at the bottom of the dishwasher indicates that the water is not being flushed/drained out but is leaking from any of the above.
Unfortunately, this is a very messy job.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
  • Louie  Role
    Louie Role Dec 15, 2008
    Another possibility is that the drain hose is kinked or blocked/clogged preventing water to flow out.
My Dishlex Global 450 leaks, I have narrowed it down to the door seal and have replaced this. It appears to overfill during it's operation BUT not evry time? Sometimes it soaks the floor other times no...
Mine did the same thing. I cleaned the door seals, mostly the bottom one which collected a lot of grime & didn't provide a solid seal.
Hope this helps.
Jan 15, 2011 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global 450
Jiggle the float in the dishwasher, turn dial or push button to cycle drain, or rince and off. Vitally
May 13, 2009 | Frigidaire 24 in. FDB126RB Built-in...
I have a dishlex global 450 and it shows ND. what does this mean?
Dec 15, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global 500 dishwasher was relocated to a new house upon first run the display showed ND for no drain, the filters are all clean and can manually siphen water out through drain hose so i know there...
when running the drain hose it must be hung from the highest point under your benchtop before draining to the sink waste. ND is sometimes displayed when the hose is not mounted high enough
Jun 06, 2008 | Dishwashers
Dishlex Global 300 Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishlex 450
I had this problem and reset the dishwasher to solve. Turn off dishwasher for at least 20 seconds, turn on while pressing eco button and wait for about 30 seconds. Should hear beeps.
May 05, 2008 | Frigidaire 24 in. FDB126RB Built-in...
My dishlex global 450 dishwasher was making a humming noise all night and dispayed OF before I disconnected the power to it. Thanks Karen kar14839@bigpond.net.au
The of means the grease trap is over full or over flowing and needs to be serviced. This is best done by a qualified serviceman.
Apr 06, 2008 | Dishwashers
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
354 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
