Question about HP Pavilion ze2000 Notebook
Hard Disk Upgrade
I would appreciate your answer to the following query:
My ze2000 came with 40gigs ... I am looking to upgrade with a minimum of 250gigs more, ideally 320Gb. I don't know which brand/ model to go for "compatibility-wise" ... WD or Seagate?? They range between $75-100 (not an issue).
Once I get the new HDD, I wish to clone my original 40Gb HDD onto it ... later format the 40Gb and use as a storage disk.
I don't know if you can call this a solution but I hope this points you in the right direction...
I personally trust WD over Seagate. Their external drives work like a dream. As for the size you wish to go with, well that is up to you. It really depends on how much you are willing to spend. Sometimes its cheaper to get the bigger size than to get the smaller one and spend more when you fill up what you have. I managed to buy a 500GB HD from Fry's for $130. Before I stray away from the issue, I would choose a WD drive, 320 over 250 GB, and I would get a friend who knows a thing or two about removing a hd from a computer so you can take it with you (just to make sure you get set up with a hd that is compatible).
Other factors that you may run into are RPM speeds. I believe they are 5400 and 7200. The faster it is then the faster things load. I also believe that the faster it is, the hotter it will get and the more power it will require. If you are concerned with getting a bigger hd then stick with what you know works, that being a 5400 rpm drive.
If you are really picky about things, I suggest going to cnet.com and reading reviews on the hd's before buying. Their reviews are very useful, they list user reviews, will compare prices with other vendors who sell the hd being reviewed and tell you if its priced according to performance or overpriced compared to similar models.
Hope that helps...
Posted on Dec 15, 2008
How we can upgrade the PS4 HDD successfully?
If you want to know about the whole process of upgrading a PS4 HDD (hard drive) on your system, you can go through the PS4 External Hard Drive, as they would provide you the easiest guidelines to upgrade your HDD very easily.
You can also get here expert IT professionals guidelines for various devices of your PS4.
Oct 14, 2016 | Sony PlayStation 4
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
Will windows 7 work on my m70 laptop
Hi
Thank you for your query
Your laptop does have the minimum spec for Windows 7, however I would recommend that you upgrade the memory from 1GB to 2 GB as it will be quite slow.
If you havent already upgraded the memory you currently have is 1 GB 533 MHz DDR2 SDRAM (2 X512MB modules), you will need to upgrade this to 2 X1GB 522MHZ DDR2 SDRAM
I hope this has been helpful.
Feb 26, 2010 | Dell Precision M70 Notebook
Hi i am trying to upgrade my window 98 to window 7 but explorer won't let me download it how can i upgrade my computer to window 7
:L You Cant Upgrade From WIndows 98 To Windows 7 Your Pc is too old and The hardware is Gonna be outta date
Nov 16, 2009 | Microsoft Windows 98 for PC
Can we install windows xp on compaq v3424 au laptop
If your laptop meets the following requirements then there shouldn't be a problem:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
I would take a system restore point BEFORE you upgrade and make sure you back up everything BEFORE you attempt an install/upgrade.
Hope this helps.
Feb 20, 2009 | Microsoft Windows XP Professional With...
Update 4090 xcdt
Yes, you can upgrade from Win98 to WinXP. The minimum hard drive requirements for WinXP is 1.5GB and the minimum RAM requirement is 64MB. You will also need a CD ROM for the install. Now those are the minimum requirements so don't expect it to go very fast. If possible I would recommend you upgrade to Win2000. WinXP and Win2000 are almost identical. The minimum hard drive for Win2000 is 650MB and for RAM it is 64MB. So you could still use your 4GB hard drive and have plenty of room. You will need a CD ROM for the Win2000 also.
Good luck if you have anymore questons let me know,
Don't forget to rate this solution before you log off.
Jan 19, 2009 | Toshiba Satellite 4090XDVD Notebook
Upgrade to vista homebasic
More than likely you can, but you need to make sure that your system meets the minimum requirements. If you had of listed your specific make and model of the system you are currently using, I would have been able to give you a definite yes/no answer. The minimum system requirements are as followings for vista home basic:
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • CD/DVD rom drive.
  • Audio Output
  • Internet access
You can also use the following windows vista upgrade advisor from Microsoft to help in making this a more easier determination.
If you would not mind, please rate my help. I would greatly appreciate it, thanks.
Sep 28, 2008 | Everex StepNote XT5000T Notebook
Hard disk upgrade for Gateway mx7118
check Gateway's support for possible help here. Most laptops can be upgraded substantially, RAM or Hard drive.
Gateway's site- I didn't see any BIOS upgrades. http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=10651&os=&type=
Perhaps someone on this site has made such an upgrade and can give you a definitive answer.
Jun 18, 2008 | Computers & Internet
FireLite FWFL40 - need to upgrade the HD
Hi, Your basically correct, the only requirement is to physically fit the enclosure (2.5inch), other than that, hard disk capacity is a matter of your personal preference/need; Toshiba is one of the better brands. Others are Seagate, Maxtor to name a few. I guess it's a matter of who can provide better after sales support. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | FireLite (USBFLB80) Hard Drive
HP Pavilion ze2000 Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
