Question about Canon MP610 Photo All-In-One Printer
Problem using OCR with Canon MP610 all-in-one
When I click the Scan Button in the OCR dialogue box I am asked to :
"Specify the Programme where the scanned image is transferred"
O do not know what to do ?
I wish to photo copy text so that it is editable in a Microsoft Word document. This was a simple procedure with My HP scanner - anyone help me to do this with my new Canon Pixma MP610
peterx
  • davidpar73 Feb 07, 2009
    Hi My mother has an MP610 and is having problems with getting the OCR to work. I read with interest Berylzir reply but as I am not conversant with the machine would appreciate a more in depth explanation on how to get the OCR to work in WORD. I am considering reinstalling the soft ware is this the only place where you can see the Open With menu.
    David
This software is unstable and far too complex. The instructions offered are abominable, but this sequence usually works for me.. Good Luck David B
Open Solutions Menu
Select Scan/Import
Select Photos/Docs
Select Photos/Docs again
Select Photos/Docs (Platen)
Doc Type - Select Text (OCR)
Click Scan
Click Exit
Select your doc (below)
Click Save
Enter file name
Save (TIFF)
Open Saved location
Select saved document
Click Edit/Convert
Select Convert to text file
Omnipage sign appears
Select Process (up high)
Select performance
Select Start
Type corrections or click Document ready and correct in Word
Highlight your doc (sall version under Doc Image)
Under Doc Image select Save to file
Click above that
Find your file in My Documents - if you are lucky !!
Posted on Jan 16, 2010
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Posted on Jan 13, 2009
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
How to scan using OCR
You must select text document in scan panel, instead of color picture. The document will be automatically redirected to ocr.
Jun 04, 2008 | Office Equipment & Supplies
How do i scan more than one sheet into a pdf document?
In Adobe Acrobat, go to -File-/-Create PDF-/-From Scanner-/-Scan-. Scan your first sheet and after it is completed, in the Acrobat Scan Dialogue box, click on -Next-, and scan the next sheet. Continue until you have finished your document and then click on -Done-. You can make your scanned document searchable by doing an OCR procedure on it by going to -Document-, -Recognise document by using OCR-/-Start-.
Aug 12, 2011 | Canon MP560 All-In-One InkJet Printer
I have Canon Lide 60 Scanner. I have to use OCR function to convert printed text to MS Word 2007. I click "OCR" on CanoScan Toolbox, select Black and White (OCR) Scan Mode. Then, it gives me...
Hello
you are doing well, just select MS word program Exe file in C:\program file\Microsoft office\officexx\winword.exe in set option of canoscan.
Then your scan will open in MS Word
Hope it will helps and do rate the solution if so
Dec 21, 2010 | Canon CanoScan LiDE 60
Which is the scan button mp520 canon printer
Easy Scanning with One-click You can complete from scanning to saving easily by simply clicking the corresponding icon.
1. Place the document face-down on the platen.
2. On the Windows desktop, double-click (MP Navigator EX 1.0).
Alternatively, on the Windows taskbar, click Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.
The MP Navigator EX navigation mode screen or one-click mode screen opens.
3. Point to One-click.
4. Click the corresponding icon.
Save to PC
Scan documents or photographs and save them to a computer.
The Save dialog box opens when you click this button. Specify the scan/save settings and scan.
Save as PDF file
Scan documents, save them as PDF files and start the specified application.
The PDF dialog box opens when you click this button. Specify the scan/save settings and scan.
Attach to E-mail
Scan documents or photographs and attach them to e-mail.
The Mail dialog box opens when you click this button. Specify the save settings and e-mail software program, and scan.
OCR
Scan text documents and open them in OmniPage SE by default.
The OCR dialog box opens when you click this button. Specify the save settings and application, and scan.
May 18, 2010 | Canon MP520 All-In-One InkJet Photo...
How do you scan a document using the Canon MP240?
download this free OCR program, install it and when you open your scanned image, just click on the OCR button and the scan will be converted to editable text.
Or just click on the MS Word button on the interface, and it will open it in Microsoft Word. In either case, you can re-work the document and re-save it or print it.
Here is the program
click here
Oct 20, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Trying to work the OCR function on Cano-scan
It means you have to select the word processor program...like microsoft word or notepad
May 28, 2009 | Canon CanoScan 8600F Flatbed Scanner
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Mar 25, 2009 | Canon CanoScan 5000F Flatbed Scanner
We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
The Scan Settings dialog box allows you to specify advanced settings for scanning.
Document Type
Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
Document Size
Select the size of document to be scanned.
Auto Detect: Detects document size automatically.
Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
Reference See the section below for details.
Scanning images Larger than the Platen (Stitch Assist)
When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
If not, some images may not be scanned at the correct positions and sizes.
You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
Select the resolution at which to scan documents. The following scanning resolution can be specified:
Text(OCR): 300dpi, 400dpi
Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
this should answer your question , feel free to post here agian if you need more help.
Regards, and thank you for using fixya.
Oct 23, 2008 | Computers & Internet
Canon printer MP470: I have never been able to use the OCR. Can you tell me how to click, click, click to do OCR? I go to MP Navigator/ One Click/ OCR/ then it says specify program where scanned...
Dear Tom,
No problem, you're a mere 17 steps away from creating a high-quality document using Canon's cutting-edge OCR software!
1. Load doc onto platen.
2. Press "SCAN" button.
3. Make sure "DOCUMENT" bar is yellow and press "OK" button.
4. Make sure "SCAN TO PC" button is yellow and press "OK" button.
5. Press "BLACK" button (w/ white diamond on it) located under the word "START" (might take a couple of tries as this button tends to stick a little.)
6. On computer screen, find image of doc that was just scanned and select it by clicking on little check box under image so a check appears. MAKE SURE NO OTHER DOCS ARE SELECTED AND/OR DE-SELECT THEM NOW.
7. On computer screen, find "double chevron" bar in lower left-hand corner and click on it.
8. Click on "EDIT/CONVERT."
9. Click on "CONVERT TO TEXT FILE."
10. This will bring up a new window. Click on the "blue arrow" with "1-2-3" next to it, located in upper left-hand corner of computer screen.
11. This will bring up a new window with three buttons to choose from. Click on the middle button, which says "PROCESS ALL UNRECOGNIZED PAGES"
12. This should start the OCR process and bring up a new window.
13. At this point, I just hit "CANCEL" and highlight & copy the OCR text by myself. (This will allow you to get around the "SPECIFY PROGRAM" program you referred to in your post.)
14. Then I open a new doc in Word (or whatever word processing program you use) and paste it directly into the new doc.
15. Then I save it into whatever folder I need to save it in.
16. Make sure to read through the doc and correct any OCR typos and/or "artifacts."
17. Save one more time to make sure you don't lose your work and you're done!
OPTIONAL 18th STEP: Open a beer and do a big bong hit -- you've earned it, soldier!
Aug 28, 2008 | Office Equipment & Supplies
Canon MP610 Photo All-In-One Printer Logo
2,876 people viewed this question
old marine
old marine
