The unit works its just when the compressor starts coming on it goes right back of
SOURCE: Power will not stay on
With a problem like this, I would use the warranty for the TV.
It's possible a circuit board failure has occurred and the TV is automatically turning itself off to protect it from further damage. Is normally called " Protection Mode " for most TVs.
Being that it's 2 months old, it should be under warranty regardless. I would recommend contacting the store of where it was purchased and have them help you with the warranty issue.
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
SOURCE: HAVE LWHD1209R & HAVE SAME
If you have not already done so then adjust pressure switch all the way up and all the way down several times.If it is sticking this may help free it up. Check all compression and other fittings for leaks. You can use a liquid dishsoap to find leaks.If all else fails then you will probably need to replace the pressure switch. Thank you.
